주요 콘텐츠로 건너뛰기
Sennheiser HD 4.50 Motherboard Replacement
필요한 것
  1. Sennheiser HD 4.50 Motherboard Replacement, Motherboard: 1 단계, 이미지 1/3 Sennheiser HD 4.50 Motherboard Replacement, Motherboard: 1 단계, 이미지 2/3 Sennheiser HD 4.50 Motherboard Replacement, Motherboard: 1 단계, 이미지 3/3
    • Locate the side designation on the headband-earpiece junction.
    • The motherboard is located on the right side.
    • Remove the right side ear pad.
    • Refer to the Ear Pad Removal guide for more guidance.
  2. Sennheiser HD 4.50 Motherboard Replacement: 2 단계, 이미지 1/3 Sennheiser HD 4.50 Motherboard Replacement: 2 단계, 이미지 2/3 Sennheiser HD 4.50 Motherboard Replacement: 2 단계, 이미지 3/3
    • Use the Phillips #00 screwdriver to remove the four 10 mm screws holding the ear cup cover in place.
    • Use an opening tool to pry off the cover.
  3. Sennheiser HD 4.50 Motherboard Replacement: 3 단계, 이미지 1/3 Sennheiser HD 4.50 Motherboard Replacement: 3 단계, 이미지 2/3 Sennheiser HD 4.50 Motherboard Replacement: 3 단계, 이미지 3/3
    • Use a Phillips #000 screwdriver to remove the four 6 mm screws holding the motherboard in place.
  4. Sennheiser HD 4.50 Motherboard Replacement: 4 단계, 이미지 1/1
    이 단계에 사용된 도구:
    구매
    • Use tweezers to remove the hot glue that covers the wires
    • Using the tweezers, grasp and slowly pull away the wires from the motherboard until they disconnect.
  5. Sennheiser HD 4.50 Motherboard Replacement: 5 단계, 이미지 1/1
    • Use the iFixit opening tools to lift up on the motherboard.
    • While lifting up with the tool, grab and pull the motherboard with your free hand away from the button functions until it disconnects.
    • There may be some resistance in this step.
  6. Sennheiser HD 4.50 Motherboard Replacement: 6 단계, 이미지 1/1
    • Desolder the three wires that are on the underside of the motherboard now that it is free.
    • Remove the motherboard.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Grace Singley
회원 가입일: 02/19/21
601 평판
안내서 5개 작성하였습니다
University of Alabama, Team S2-G1, Bedsole Spring 2021 University of Alabama, Team S2-G1, Bedsole Spring 2021 회원
UA-BEDSOLE-S21S2G1
4 회원들
안내서 16개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 21
30일 전: 93
전체 시간: 2,642
