주요 콘텐츠로 건너뛰기
Sennheiser Momentum Wireless M2 AEBT Adjustable Sliding Hinges Replacement
필요한 것
  1. Sennheiser Momentum Wireless M2 AEBT Adjustable Sliding Hinges Replacement, Earmuff: 1 단계, 이미지 1/1
    • Grab the earmuffs with one hand and hold the headphones with the other.
  2. Sennheiser Momentum Wireless M2 AEBT Adjustable Sliding Hinges Replacement: 2 단계, 이미지 1/1
    • Pull the earmuff until it separates from headphones as shown.
  3. Sennheiser Momentum Wireless M2 AEBT Adjustable Sliding Hinges Replacement, Adjustable Sliding Hinges: 3 단계, 이미지 1/1
    • Remove the four 8mm screws on the ear cup using a #000 Phillips screwdriver to reveal the motherboard.
  4. Sennheiser Momentum Wireless M2 AEBT Adjustable Sliding Hinges Replacement: 4 단계, 이미지 1/3 Sennheiser Momentum Wireless M2 AEBT Adjustable Sliding Hinges Replacement: 4 단계, 이미지 2/3 Sennheiser Momentum Wireless M2 AEBT Adjustable Sliding Hinges Replacement: 4 단계, 이미지 3/3
    • On one half of the ear cup that was previously removed, there will be located a motherboard. On the other half there will be a coupler holding the cup to the hinge and allowing it to move in a 360 degree manner. Remove this coupler by unscrewing the 10mm screw with the same #000 Phillips screwdriver.
  5. Sennheiser Momentum Wireless M2 AEBT Adjustable Sliding Hinges Replacement: 5 단계, 이미지 1/2 Sennheiser Momentum Wireless M2 AEBT Adjustable Sliding Hinges Replacement: 5 단계, 이미지 2/2
    • On the leather part of the headset, four 6mm Torx screws need to be removed using a T6H Torx screwdriver.
  6. Sennheiser Momentum Wireless M2 AEBT Adjustable Sliding Hinges Replacement: 6 단계, 이미지 1/2 Sennheiser Momentum Wireless M2 AEBT Adjustable Sliding Hinges Replacement: 6 단계, 이미지 2/2
    • On the other side of the 6mm torx screws, there is a nameplate that needs to be pried off using a pry tool.
  7. Sennheiser Momentum Wireless M2 AEBT Adjustable Sliding Hinges Replacement: 7 단계, 이미지 1/3 Sennheiser Momentum Wireless M2 AEBT Adjustable Sliding Hinges Replacement: 7 단계, 이미지 2/3 Sennheiser Momentum Wireless M2 AEBT Adjustable Sliding Hinges Replacement: 7 단계, 이미지 3/3
    • Steps 1-4 need to be repeated for the other ear cup.
결론
The hinges must be removed from BOTH sides of the headphones for even one side to come out. They are attached together.
welsayed
회원 가입일: 09/08/23
319 평판
안내서 3개 작성하였습니다
University of New Orleans, Team 5-2, McDonald Fall 2023 University of New Orleans, Team 5-2, McDonald Fall 2023 회원
UNO-MCDONALD-F23S5G2
3 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 8
30일 전: 24
전체 시간: 157
