소개
The headphones not charging or needing to be charged constantly can be due to a faulty battery. This guide will help educate users on how to remove and replace a faulty or broken battery. The process is moderately difficult, it requires the use of the standard #00 Philips screwdriver and a new battery which can be received from a Sennheiser facility.
필요한 것
Use the #00 Philips screwdriver to unscrew the four 8mm screws.
Grab the cover and carefully pull off to view inside of headphone.
다른 한 분이 해당 안내서를 완성하였습니다.
