주요 콘텐츠로 건너뛰기
Sennheiser Momentum Wireless M2 AEBT Charging Port/Volume Control Replacement
필요한 것
  1. Sennheiser Momentum Wireless M2 AEBT Charging Port/Volume Control Replacement, Earmuff: 1 단계, 이미지 1/1
    • Grab the earmuffs with one hand and hold the headphones with the other.
  2. Sennheiser Momentum Wireless M2 AEBT Charging Port/Volume Control Replacement: 2 단계, 이미지 1/1
    • Pull the earmuff until it separates from headphones as shown.
  3. Sennheiser Momentum Wireless M2 AEBT Charging Port/Volume Control Replacement, Charging Port/Volume Control: 3 단계, 이미지 1/2 Sennheiser Momentum Wireless M2 AEBT Charging Port/Volume Control Replacement, Charging Port/Volume Control: 3 단계, 이미지 2/2
    • After removing the muffs, the speaker cover must be removed by unscrewing 4 3mm Phillips screws using a #000 Phillips screwdriver.
  4. Sennheiser Momentum Wireless M2 AEBT Charging Port/Volume Control Replacement: 4 단계, 이미지 1/1
    • After locating the circuit board that contains the charging port as well as the volume control dial, two 3 mm screws must be removed using a #000 phillips screwdriver.
  5. Sennheiser Momentum Wireless M2 AEBT Charging Port/Volume Control Replacement: 5 단계, 이미지 1/1
    • Unplug the blue ribbon attaching the circuit board to the motherboard.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
welsayed
회원 가입일: 09/08/23
319 평판
안내서 3개 작성하였습니다
University of New Orleans, Team 5-2, McDonald Fall 2023 University of New Orleans, Team 5-2, McDonald Fall 2023 회원
UNO-MCDONALD-F23S5G2
3 회원들
안내서 7개 작성하였습니다
댓글 2개
where do I get the replacement module?
Jan G - 답글
Have you found one yet? I've needed to do this repair for a while.
Paul B -
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 6
30일 전: 64
전체 시간: 397
