주요 콘텐츠로 건너뛰기
Sennheiser Momentum Wireless M2 AEBT Motherboard Replacement
필요한 것
  1. Sennheiser Momentum Wireless M2 AEBT Motherboard Replacement, Earmuff: 1 단계, 이미지 1/1
    • Grab the earmuffs with one hand and hold the headphones with the other.
  2. Sennheiser Momentum Wireless M2 AEBT Motherboard Replacement: 2 단계, 이미지 1/1
    • Pull the earmuff until it separates from headphones as shown.
  3. Sennheiser Momentum Wireless M2 AEBT Motherboard Replacement, Motherboard: 3 단계, 이미지 1/1
    • Remove the 4 8mm screws with a #000 Philips screw driver.
  4. Sennheiser Momentum Wireless M2 AEBT Motherboard Replacement: 4 단계, 이미지 1/1
    • Remove the 2 2mm screws using a #000 phillips screwdriver.
  5. Sennheiser Momentum Wireless M2 AEBT Motherboard Replacement: 5 단계, 이미지 1/1
    • Using a soldering iron, remove all the wires attached to the motherboard and other components.
  6. Sennheiser Momentum Wireless M2 AEBT Motherboard Replacement: 6 단계, 이미지 1/1
    이 단계에 사용된 도구:
    구매
    • Finally, remove the blue ribbon plugged into the motherboard.
    • Make sure to do this using tweezers, so as to avoid any damage to the fragile ribbon.
결론
nasaintj
회원 가입일: 09/08/23
159 평판
안내서 1개 작성함
University of New Orleans, Team 5-2, McDonald Fall 2023 University of New Orleans, Team 5-2, McDonald Fall 2023 회원
UNO-MCDONALD-F23S5G2
3 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 13
30일 전: 44
전체 시간: 207
