주요 콘텐츠로 건너뛰기
Sennheiser RS120 Battery Replacement
필요한 것
  1. Sennheiser RS120 Battery Replacement, Ear Pad: 1 단계, 이미지 1/3 Sennheiser RS120 Battery Replacement, Ear Pad: 1 단계, 이미지 2/3 Sennheiser RS120 Battery Replacement, Ear Pad: 1 단계, 이미지 3/3
    • Grip the ear pad with one hand and steady the headset on the other.
    • Twist the ear pad counterclockwise, then lift the ear pad off after about an eighth of an inch of the turn.
    • Replace the old ear pad with a new ear pad.
  2. Sennheiser RS120 Battery Replacement, Battery: 2 단계, 이미지 1/2 Sennheiser RS120 Battery Replacement, Battery: 2 단계, 이미지 2/2
    • Twist the left ear pad counterclockwise to reveal the battery compartment within the headphone.
    • To remove batteries, push inward and lift up.
    • The battery should be able to pop out.
결론
다른 15명이 해당 안내서를 완성하였습니다.
Gayle Dunham
회원 가입일: 03/03/10
375 평판
안내서 1개 작성함
댓글 7개
Thanks for the information - this made changing the batteries a snap.
Jim K - 답글
Extremely helpful. Thank you!
-Randy N
Randy - 답글
I own three sets and one quit working. As it turns out that the rechargeable batteries in that one set need replacing.
Until I purchase some rechargeable batteries, I am using standard AAA batteries and just have to remember NOT to put the headset back on the cradle.
Thanks for the info on how to access the batteries !
mcgilljp - 답글
Thanks! You solved my mystery.
Marilyn Carini - 답글
Good information, I wouldn’t have had a clue without it. Many thanks
Geoff Smith - 답글
my kids putin regular batteries did this ruin head set?
judith langley - 답글
how do you know when it's time to replace the rechargeable batteries? The headphones work, but begin to buzz after a bit. The buzz makes listening impossible. Is that the batteries?
kristen rinaker - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 29
30일 전: 129
전체 시간: 44,451
