주요 콘텐츠로 건너뛰기
Separate Samsung SGH-X105 Front & Back Panels
필요한 것
  1. Separate Samsung SGH-X105 Front & Back Panels, Battery: 1 단계, 이미지 1/1
    • Rotate the phone onto its front side so that the LCD screen is facing away from you.
  2. Separate Samsung SGH-X105 Front & Back Panels: 2 단계, 이미지 1/3 Separate Samsung SGH-X105 Front & Back Panels: 2 단계, 이미지 2/3 Separate Samsung SGH-X105 Front & Back Panels: 2 단계, 이미지 3/3
    • Remove the battery by pressing down on the battery release button while sliding the battery downwards.
  3. Separate Samsung SGH-X105 Front & Back Panels, Front & Back Panels: 3 단계, 이미지 1/1
    • Remove the four small black screws that secure the back phone panel using the Phillips #00 screwdriver.
    • Complete removal of screws may not be necessary.
  4. Separate Samsung SGH-X105 Front & Back Panels: 4 단계, 이미지 1/3 Separate Samsung SGH-X105 Front & Back Panels: 4 단계, 이미지 2/3 Separate Samsung SGH-X105 Front & Back Panels: 4 단계, 이미지 3/3
    • Carefully separate the front and back panels by gently prying them apart. Start at the bottom of the phone (near the AC charger input).
    • Volume control button will be unsecured and may fall out as soon as the panels are separated.
    • Gentle force may be required to separate the panels at the top latch.
    • There are two wires connecting the front and back panels. Be careful not to rip these wires out when separating the panels.
  5. Separate Samsung SGH-X105 Front & Back Panels: 5 단계, 이미지 1/2 Separate Samsung SGH-X105 Front & Back Panels: 5 단계, 이미지 2/2
    이 단계에 사용된 도구:
    구매
    • Using your nails, tweezers, or any precise grabbing tool, pinch the antenna wire connector (clear plastic plug) and pull gently. It should pop out rather easily.
결론
DJ Tarazona
회원 가입일: 04/13/10
58 평판
안내서 3개 작성하였습니다
Cal Poly, Team 28-29, Regan Spring 2010 Cal Poly, Team 28-29, Regan Spring 2010 회원
CPSU-REGAN-S10S28G29
4 회원들
안내서 12개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 13
전체 시간: 1,860
