주요 콘텐츠로 건너뛰기
Separating Rear Board
필요한 것
  1. Separating Rear Board, Remove Battery: 1 단계, 이미지 1/3 Separating Rear Board, Remove Battery: 1 단계, 이미지 2/3 Separating Rear Board, Remove Battery: 1 단계, 이미지 3/3
    • Place the controller face down.
    • Remove the battery cover.
    • Remove rechargeable battery or AA batteries.
  2. Separating Rear Board, Remove Trigger Buttons: 2 단계, 이미지 1/2 Separating Rear Board, Remove Trigger Buttons: 2 단계, 이미지 2/2
    • Remove L2 and R2 trigger buttons by pushing them away from the grips.
  3. Separating Rear Board, Remove Screws: 3 단계, 이미지 1/2 Separating Rear Board, Remove Screws: 3 단계, 이미지 2/2
    • Use Tweezers to uncover two screws under the label in the battery compartment.
    • Use a T6 screwdriver to remove the four 7.3 mm screws securing the rear cover.
  4. Separating Rear Board, Unclip Covers: 4 단계, 이미지 1/3 Separating Rear Board, Unclip Covers: 4 단계, 이미지 2/3 Separating Rear Board, Unclip Covers: 4 단계, 이미지 3/3
    • At the end of each grip, pry apart the covers.
    • Use fingernail or opening pick to undo the two top clips.
    • One clip next to L button.
    • One clip next to R button
    • Undo the final clip between the joysticks.
  5. Separating Rear Board, Separate Covers: 5 단계, 이미지 1/1
    • Carefully move the rear cover away and from the front cover. Place it to the left.
    • Do not completely separate. The two halves are still attached via a white ribbon cable.
  6. Separating Rear Board, Remove Ribbon Cable: 6 단계, 이미지 1/3 Separating Rear Board, Remove Ribbon Cable: 6 단계, 이미지 2/3 Separating Rear Board, Remove Ribbon Cable: 6 단계, 이미지 3/3
    • Unlock the ribbon cable by push open the black plastic tab.
    • The tab will slide about 1.5mm
    • Pull the ribbon cable out of the connector in the direction of the cable.
  7. Separating Rear Board, Remove Caps: 7 단계, 이미지 1/2 Separating Rear Board, Remove Caps: 7 단계, 이미지 2/2
    • Grab the top and pull straight up on the joystick cap. Pulling out the caps one-by-one.
  8. Separating Rear Board, Remove Screws: 8 단계, 이미지 1/3 Separating Rear Board, Remove Screws: 8 단계, 이미지 2/3 Separating Rear Board, Remove Screws: 8 단계, 이미지 3/3
    • Use a Phillips screwdriver to remove the nine 5.2 mm screws securing the rear circuit board.
    • Four around the Right stick
    • Four around the Left stick
    • One next to the Battery connector
  9. Separating Rear Board, Separate Rear Board: 9 단계, 이미지 1/3 Separating Rear Board, Separate Rear Board: 9 단계, 이미지 2/3 Separating Rear Board, Separate Rear Board: 9 단계, 이미지 3/3
    • Pull the two rumble motors out of their housings.
    • Grab the analog sticks to pull out the circuit board
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Brian W
회원 가입일: 12/21/11
1,224 평판
안내서 8개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 2
전체 시간: 343
