주요 콘텐츠로 건너뛰기
SereneLife Treadmill SLFTRD20 Belt Adjustment
필요한 것
  1. SereneLife Treadmill SLFTRD20 Belt Adjustment, SereneLife Treadmill SLFTRD20 Belt Adjustment: 1 단계, 이미지 2개 중 1개 SereneLife Treadmill SLFTRD20 Belt Adjustment, SereneLife Treadmill SLFTRD20 Belt Adjustment: 1 단계, 이미지 2개 중 2개
    • Turn on the main power switch.
  2. SereneLife Treadmill SLFTRD20 Belt Adjustment: 2 단계, 이미지 2개 중 1개 SereneLife Treadmill SLFTRD20 Belt Adjustment: 2 단계, 이미지 2개 중 2개
    • Begin by pressing the "Start" button on the machine.
    • Let the treadmill belt run at the lowest setting.
  3. SereneLife Treadmill SLFTRD20 Belt Adjustment: 3 단계, 이미지 2개 중 1개 SereneLife Treadmill SLFTRD20 Belt Adjustment: 3 단계, 이미지 2개 중 2개
    • In order to locate the roller adjustment bolts, try locating the rear left cover and rear right cover.
  4. SereneLife Treadmill SLFTRD20 Belt Adjustment: 4 단계, 이미지 3개 중 1개 SereneLife Treadmill SLFTRD20 Belt Adjustment: 4 단계, 이미지 3개 중 2개 SereneLife Treadmill SLFTRD20 Belt Adjustment: 4 단계, 이미지 3개 중 3개
    • Remove the attached rear left and right covers from the treadmill.
    • After removing the rear covers, you'll be able to see the adjustment bolts.
  5. SereneLife Treadmill SLFTRD20 Belt Adjustment: 5 단계, 이미지 2개 중 1개 SereneLife Treadmill SLFTRD20 Belt Adjustment: 5 단계, 이미지 2개 중 2개
    • Before we begin it's important to determine which side the belt is shifting towards.
    • If the belt is shifting to the right, then turn the right adjustment bolt to turn 1/4 clockwise. If the belt is shifting to the left, then turn the left adjustment bolt to turn 1/4 clockwise.
    • Place the Allen wrench in the left rear roller bolt.
    • Turn the left roller bolt adjustment to turn one-fourth clockwise.
    • Now stop and wait for the belt to begin to center itself.
    • You must wait for the belt to re-center between each adjustment to ensure that you do not overcorrect the belt.
  6. SereneLife Treadmill SLFTRD20 Belt Adjustment: 6 단계, 이미지 1개 중 1개
    • In order to fix the slipping belt during use, we need to turn off and unplug the Treadmill.
  7. SereneLife Treadmill SLFTRD20 Belt Adjustment: 7 단계, 이미지 3개 중 1개 SereneLife Treadmill SLFTRD20 Belt Adjustment: 7 단계, 이미지 3개 중 2개 SereneLife Treadmill SLFTRD20 Belt Adjustment: 7 단계, 이미지 3개 중 3개
    • Place the Allen wrench in the left roller bolt and turn it 1/4 clockwise to tighten the belt.
    • Repeat on the right side of the roller bolt in the same way.
  8. SereneLife Treadmill SLFTRD20 Belt Adjustment: 8 단계, 이미지 2개 중 1개 SereneLife Treadmill SLFTRD20 Belt Adjustment: 8 단계, 이미지 2개 중 2개
    • Attach the rear covers onto the left side and right side of the frames.
    • Turn the main power switch back on and run the treadmill at the lowest speed.
    • Run on the treadmill to determine if the belt is still slipping or not.
    • Repeat this procedure until the belt no longer slips.
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Alina Abbas
회원 가입일: 07/03/21
211 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 17
전체 시간: 2,321
