주요 콘텐츠로 건너뛰기
Seville Classics MSC10166 Buttons Replacement
필요한 것
  1. Seville Classics MSC10166 Buttons Replacement, PCB (Printed Circuit Board): 1 단계, 이미지 1개 중 1개
    • Use the Phillips #2 screwdriver to remove the four 6 mm screws by unscrewing counterclockwise.
  2. Seville Classics MSC10166 Buttons Replacement: 2 단계, 이미지 1개 중 1개
    • Pull the front and back cover apart.
    • Be careful not to pull the front cover off completely. It holds the wires.
  3. Seville Classics MSC10166 Buttons Replacement: 3 단계, 이미지 1개 중 1개
    • Remove the Phillips 6 mm screw that holds the circuit board to the outer shell of the fan.
    • Shock warning: Make sure the fan is unplugged before removing the circuit board.
  4. Seville Classics MSC10166 Buttons Replacement: 4 단계, 이미지 1개 중 1개
    • Remove the top cover containing the circuit board and the wires by pulling it away from the outer shell of the fan.
  5. Seville Classics MSC10166 Buttons Replacement: 5 단계, 이미지 2개 중 1개 Seville Classics MSC10166 Buttons Replacement: 5 단계, 이미지 2개 중 2개
    • Remove the screws from the four corners of the circuit board.
    • Remove the circuit board from the top cover.
    • Do not touch the other side of the circuit board to avoid damaging the circuit elements.
  6. Seville Classics MSC10166 Buttons Replacement, Buttons: 6 단계, 이미지 1개 중 1개
    • Remove the two 8 mm screws that attach the buttons to the top cover of the fan.
  7. Seville Classics MSC10166 Buttons Replacement: 7 단계, 이미지 1개 중 1개
    • Remove the buttons from the top cover.
  8. Seville Classics MSC10166 Buttons Replacement: 8 단계, 이미지 1개 중 1개
    • Wipe down any dirt on the buttons.
  9. Seville Classics MSC10166 Buttons Replacement: 9 단계, 이미지 1개 중 1개
    • Wipe down the frame that holds the buttons.
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
11다른 기여자 명과 함께
Queena Phung
회원 가입일: 09/26/12
114 평판
안내서 3개를 작성함
Cal Poly, Team 15-46, Forte Fall 2012 Cal Poly, Team 15-46, Forte Fall 2012 회원
CPSU-FORTE-F12S15G46
5 회원들
안내서 6개를 작성함
2가이드 댓글
Great work but our problem is the micro switch itself, after exposing the circuit board I shorted the backside solder connections to cycle the fan on and off, everything works perfectly…..now I only need to know a part number so I can find a on/off micro switch.
any suggestions?
Thanks for any help you can provide
rickkingsbury@comcast.net
Rick - 답글
Is there a way to keep the fan in ALWAYS ON position. So I can control it’s ON/OFF using a smart plug?
Vish Talreja - 답글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 5
지난 30일: 21
전체 시간: 4,400
