주요 콘텐츠로 건너뛰기
Seville Classics MSC10166 PCB (Printed Circuit Board) Replacement
필요한 것
  1. Seville Classics MSC10166 PCB (Printed Circuit Board) Replacement, PCB (Printed Circuit Board): 1 단계, 이미지 1개 중 1개
    • Use the Phillips #2 screwdriver to remove the four 6 mm screws by unscrewing counterclockwise.
  2. Seville Classics MSC10166 PCB (Printed Circuit Board) Replacement: 2 단계, 이미지 1개 중 1개
    • Pull the front and back cover apart.
    • Be careful not to pull the front cover off completely. It holds the wires.
  3. Seville Classics MSC10166 PCB (Printed Circuit Board) Replacement: 3 단계, 이미지 1개 중 1개
    • Remove the Phillips 6 mm screw that holds the circuit board to the outer shell of the fan.
    • Shock warning: Make sure the fan is unplugged before removing the circuit board.
  4. Seville Classics MSC10166 PCB (Printed Circuit Board) Replacement: 4 단계, 이미지 1개 중 1개
    • Remove the top cover containing the circuit board and the wires by pulling it away from the outer shell of the fan.
  5. Seville Classics MSC10166 PCB (Printed Circuit Board) Replacement: 5 단계, 이미지 2개 중 1개 Seville Classics MSC10166 PCB (Printed Circuit Board) Replacement: 5 단계, 이미지 2개 중 2개
    • Remove the screws from the four corners of the circuit board.
    • Remove the circuit board from the top cover.
    • Do not touch the other side of the circuit board to avoid damaging the circuit elements.
결론
작성자
12다른 기여자 명과 함께
Mateo Begue
회원 가입일: 09/26/12
102 평판
안내서 2개를 작성함
Cal Poly, Team 15-46, Forte Fall 2012 Cal Poly, Team 15-46, Forte Fall 2012 회원
CPSU-FORTE-F12S15G46
5 회원들
안내서 6개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 3
지난 30일: 16
전체 시간: 1,683
