소개
A ladder stitch, or closure stitch, is a sewing technique that allows you to close a tear without leaving the stitching visible.
The trick is to make the stitches as small and as even as possible. This technique works for repairing almost any type of tear.
필요한 것
Thread your needle and tie a knot in the end.
Drive the needle from the back of the material, just before where the tear starts.
Pull the thread taut.
One the last stitch, drive the needle through both sides of the fabric, taking as small of a stitch as possible.
Slowly pull the thread. As you pull, a loop will form. Draw the needle through this loop, and pull the thread taut.
Repeat this step, taking a tiny stitch, drawing the needle through the loop, and pulling taut.
Ensure that the stitches are tight, and cut any excess threads.
다른 2명이 해당 안내서를 완성하였습니다.
