이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Thread your needle and tie a knot in the end.
Drive the needle from the back of the material, just before where the tear starts.
Pull the thread taut.
Take a small stitch, going in and out of the material, on one side of the tear only.
Take a small stitch, going in and out of the material, on the other side of the tear, directly opposite of the stitch you just took.
Pull the thread taut. This should cinch the material together.
Continue stitching, switching from side to side as described in step 2 and 3 of this guide, pulling the thread taut after each stitch.
Stitch until you come to the end of the tear.
One the last stitch, drive the needle through both sides of the fabric, taking as small of a stitch as possible.
Slowly pull the thread. As you pull, a loop will form. Draw the needle through this loop, and pull the thread taut.
Repeat this step, taking a tiny stitch, drawing the needle through the loop, and pulling taut.
Ensure that the stitches are tight, and cut any excess threads.
다른 2명이 해당 안내서를 완성하였습니다.
