이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Examine the damage. Clip any loose threads and remove any debris from the tear.
Grab a trendy patch.
Position the patch over the hole.
Any patch you use should overlap the damage by at least 1/8".
Slide the jeans into the sewing machine, positioning the needle over the edge of the patch.
Lower the pressor foot.
Sew along the edge of the patch.
Remove the pins before you get to them.
Continue sewing around the patch, lifting the pressor foot to turn at corners of the patch.
When you come all the way around, overlap the first two or three stitches.
Lift the needle and pressor foot.
Slide the jeans out of the sewing machine.
Clip any threads, and admire your work.
다른 4명이 해당 안내서를 완성하였습니다.
