주요 콘텐츠로 건너뛰기
Shank Button Replacement
필요한 것
  1. Shank Button Replacement, Shank Button: 1 단계, 이미지 3개 중 1개 Shank Button Replacement, Shank Button: 1 단계, 이미지 3개 중 2개 Shank Button Replacement, Shank Button: 1 단계, 이미지 3개 중 3개
    • Remove your loose button (if necessary).
    • If the button is already missing, remove any loose threads from your garment.
    • Mark where the button was on the garment to hold place (a felt tip pen works fine, just keep the marking small)
  2. Shank Button Replacement: 2 단계, 이미지 3개 중 1개 Shank Button Replacement: 2 단계, 이미지 3개 중 2개 Shank Button Replacement: 2 단계, 이미지 3개 중 3개
    • Measure out your thread. An easy measuring reference is the length of one arm fully extended.
    • Thread your needle.
    • Pull the thread until two equal parts are on either side of the needle.
    • Tie a knot in the end of your thread (both ends should be tied together creating a double thread).
  3. Shank Button Replacement: 3 단계, 이미지 3개 중 1개 Shank Button Replacement: 3 단계, 이미지 3개 중 2개 Shank Button Replacement: 3 단계, 이미지 3개 중 3개
    • Insert your needle into the marked space where your needle should go on the top side of the garment (that way the button will hide your knot).
    • Pull the thread until the knot rests on the fabric.
    • Insert your needle into the shank on the back of your button.
    • Pull the thread until the button rests on the fabric.
    • Insert the needle back into the same space on your fabric. Repeat the above instructions 5 times or until the button is firmly attached.
  4. Shank Button Replacement: 4 단계, 이미지 3개 중 1개 Shank Button Replacement: 4 단계, 이미지 3개 중 2개 Shank Button Replacement: 4 단계, 이미지 3개 중 3개
    • To tie off your thread, insert the needle back into the fabric near your previous stitches.
    • Pull thread until there is a small loop (do not pull flush with fabric).
    • Insert the needle into the thread loop and pull through.
    • Pull the thread until the loop closes and a knot is formed.
  5. Shank Button Replacement: 5 단계, 이미지 3개 중 1개 Shank Button Replacement: 5 단계, 이미지 3개 중 2개 Shank Button Replacement: 5 단계, 이미지 3개 중 3개
    • Trim any excess thread from the button area.
    • Enjoy your newly repaired item!
결승점
작성자
2다른 기여자 명과 함께
Rebekah Kilpatrick
회원 가입일: 09/20/23
121 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 8
지난 30일: 30
전체 시간: 608
