주요 콘텐츠로 건너뛰기
Shark Cordless Pet Perfect Battery Replacement
필요한 것
  1. Shark Cordless Pet Perfect Battery Replacement, Battery: 1 단계, 이미지 1/3 Shark Cordless Pet Perfect Battery Replacement, Battery: 1 단계, 이미지 2/3 Shark Cordless Pet Perfect Battery Replacement, Battery: 1 단계, 이미지 3/3
    • Remove the Dust Cap Container then remove the 7.5mm screw (with the PH2 Bit) from the battery cover.
    • Using a black spudger pry open the cover, and remove the cover plate.
  2. Shark Cordless Pet Perfect Battery Replacement: 2 단계, 이미지 1/2 Shark Cordless Pet Perfect Battery Replacement: 2 단계, 이미지 2/2
    • Once the battery cover is removed slide the battery mount upwards and pull it out.
  3. Shark Cordless Pet Perfect Battery Replacement: 3 단계, 이미지 1/3 Shark Cordless Pet Perfect Battery Replacement: 3 단계, 이미지 2/3 Shark Cordless Pet Perfect Battery Replacement: 3 단계, 이미지 3/3
    • Pull out the battery and then disconnect the battery at the quick disconnects.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Ashley Calkins
회원 가입일: 02/02/17
560 평판
안내서 3개 작성하였습니다
USF Tampa, Team 16-2, Blackwell Spring 2017 USF Tampa, Team 16-2, Blackwell Spring 2017 회원
USFT-BLACKWELL-S17S16G2
4 회원들
안내서 11개 작성하였습니다
댓글 4개
Throw it away and buy new lithium Pet Perfect
John Carson - 답글
I changed the battery, it still shuts off after 1 second
Garry - 답글
It has a 2 year warranty, mine quit working at 2 years 10 months. Pretty expensive for only 34 months.
Ralph E Beaver - 답글
Mine still working after 3 (three)years and it was $45 at the time from Walmart. Wouldn't be cheaper to buy an other whole unit than waste $45 plus tax, plus work just on the battery pack like Amazon's Banshee ( read EXTRATERRESTRIAL ) battery pack of $45 plus tax ???
Aurel Tita - 답글
댓글 쓰기
조회 통계:
24 시간 전: 7
7일 전: 25
30일 전: 88
전체 시간: 13,828
