주요 콘텐츠로 건너뛰기
Shark Cordless Pet Perfect Charging Port Replacement
필요한 것
  1. Shark Cordless Pet Perfect Charging Port Replacement, Charging Port: 1 단계, 이미지 1/3 Shark Cordless Pet Perfect Charging Port Replacement, Charging Port: 1 단계, 이미지 2/3 Shark Cordless Pet Perfect Charging Port Replacement, Charging Port: 1 단계, 이미지 3/3
    • Remove the dust cup container from the motor housing.
  2. Shark Cordless Pet Perfect Charging Port Replacement: 2 단계, 이미지 1/3 Shark Cordless Pet Perfect Charging Port Replacement: 2 단계, 이미지 2/3 Shark Cordless Pet Perfect Charging Port Replacement: 2 단계, 이미지 3/3
    • Remove the five 14mm screws with the PH 2 bit. Once all the screws are removed, pull one part of the housing away from the other.
  3. Shark Cordless Pet Perfect Charging Port Replacement: 3 단계, 이미지 1/3 Shark Cordless Pet Perfect Charging Port Replacement: 3 단계, 이미지 2/3 Shark Cordless Pet Perfect Charging Port Replacement: 3 단계, 이미지 3/3
    • Pull the charging port mount away from the housing. Once separated, pull the the charging port out of the mount to access the charging port itself.
  4. Shark Cordless Pet Perfect Charging Port Replacement: 4 단계, 이미지 1/2 Shark Cordless Pet Perfect Charging Port Replacement: 4 단계, 이미지 2/2
결론
다른 4명이 해당 안내서를 완성하였습니다.
Ashley Calkins
회원 가입일: 02/02/17
560 평판
안내서 3개 작성하였습니다
USF Tampa, Team 16-2, Blackwell Spring 2017 USF Tampa, Team 16-2, Blackwell Spring 2017 회원
USFT-BLACKWELL-S17S16G2
4 회원들
안내서 11개 작성하였습니다
댓글 3개
yeah thanks buddy real helpful
James Melendez - 답글
not really though, any dunce can get this far. what part is used in the replacement? if replacing this part does not fix the problem, what are my alternatives? are there any tests i could run with a multimeter, say on the charger, battery, or any terminals? too light of an article in my opinion. anyone who can remove screws can get this far, where is there any electrical expertise involved? a real electrician would take a layman from start to finish, including tests to make sure replacing a part is worth the time and money, as in, will simply replacing the terminal actually fix the problem? we’ll find out the hard way. more advice needed in my opinion.
James Melendez - 답글
replacement part not listed is my main beef, to be honest, and a DMM test or two to be sure of the problem would be nice.
James Melendez - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 11
전체 시간: 3,842
