주요 콘텐츠로 건너뛰기
Shark Cordless Pet Perfect Front Belt Replacement
필요한 것
  1. Shark Cordless Pet Perfect Front Belt Replacement, Front Belt: 1 단계, 이미지 1/2 Shark Cordless Pet Perfect Front Belt Replacement, Front Belt: 1 단계, 이미지 2/2
    • Remove the two 12mm screws from the front face plate with the PH2 bit from the tool kit.
  2. Shark Cordless Pet Perfect Front Belt Replacement: 2 단계, 이미지 1/3 Shark Cordless Pet Perfect Front Belt Replacement: 2 단계, 이미지 2/3 Shark Cordless Pet Perfect Front Belt Replacement: 2 단계, 이미지 3/3
    • Once the screws are removed pull the front face plate off. This will allow access to the belt and motor.
  3. Shark Cordless Pet Perfect Front Belt Replacement: 3 단계, 이미지 1/3 Shark Cordless Pet Perfect Front Belt Replacement: 3 단계, 이미지 2/3 Shark Cordless Pet Perfect Front Belt Replacement: 3 단계, 이미지 3/3
    • Lift the brush roller upwards towards you, and the brush roller should come out along with the belt.
  4. Shark Cordless Pet Perfect Front Belt Replacement: 4 단계, 이미지 1/2 Shark Cordless Pet Perfect Front Belt Replacement: 4 단계, 이미지 2/2
    • Remove the belt from the motor mount, and then replace with a new belt.
결론
Ben Dzugen
회원 가입일: 02/02/17
383 평판
안내서 3개 작성하였습니다
USF Tampa, Team 16-2, Blackwell Spring 2017 USF Tampa, Team 16-2, Blackwell Spring 2017 회원
USFT-BLACKWELL-S17S16G2
4 회원들
안내서 11개 작성하였습니다
댓글 2개
Nice and simple but where can we purchase the belts?
jmrlachance - 답글
My shark pet vacuum didn't come with lint brush roller. How do I get one. I buy these pet vacuum for friends/family. Please respond
Tina Cherney - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 8
30일 전: 28
전체 시간: 2,665
