주요 콘텐츠로 건너뛰기
Shark DuoClean Powered Lift-Away Speed Brushroll Replacement
  1. Shark DuoClean Powered Lift-Away Speed Brushroll Replacement, Brushroll: 1 단계, 이미지 1/3 Shark DuoClean Powered Lift-Away Speed Brushroll Replacement, Brushroll: 1 단계, 이미지 2/3 Shark DuoClean Powered Lift-Away Speed Brushroll Replacement, Brushroll: 1 단계, 이미지 3/3
    • Press the two Brush Roll Access buttons down at the same time to detach the cover.
    • Pull the cover off of the vacuum by lifting it up.
  2. Shark DuoClean Powered Lift-Away Speed Brushroll Replacement: 2 단계, 이미지 1/2 Shark DuoClean Powered Lift-Away Speed Brushroll Replacement: 2 단계, 이미지 2/2
    • Pull up on the Pull Tab to remove the large brush roll.
  3. Shark DuoClean Powered Lift-Away Speed Brushroll Replacement: 3 단계, 이미지 1/2 Shark DuoClean Powered Lift-Away Speed Brushroll Replacement: 3 단계, 이미지 2/2
    • Press the Eject Roller button to detach the small roller.
    • Pull the roller away from the vacuum to remove it.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Catie Halvorsen
회원 가입일: 10/08/18
703 평판
안내서 5개 작성하였습니다
Cal Poly, Team S17-G4, White Fall 2018 Cal Poly, Team S17-G4, White Fall 2018 회원
CPSU-WHITE-F18S17G4
4 회원들
안내서 16개 작성하였습니다
댓글 한 개
I need help with removing the beater bar on the nv835 I can't find help nowhere
Ethel McClintock - 답글
댓글 쓰기
조회 통계:
24 시간 전: 11
7일 전: 83
30일 전: 374
전체 시간: 34,876
