소개
If the drive belt is out of place or jammed, use this guide to replace the drive belt. You will need the T10 and T20 Torx screwdrivers.
필요한 것
Press the two Brush Roll Access buttons down at the same time to detach the cover.
Pull the cover off of the vacuum by lifting it up.
Use the T20 screwdriver to remove the four 17 mm screws by turning counterclockwise.
다른 15명이 해당 안내서를 완성하였습니다.
댓글 38개
What a pain in the ***! The star bit wouldn't fit on one of the screws and had to use a small reg. screwdriver to get it out. This is a very poor design. I've only used the sweeper a few times too. Hope the belts don't come off or break often because if they do it's going in the dumpster and never buying another one. Do not recommend this sweeper!!! Very disappointed.
What size belt I need for this vacuum
Very bad design will stick to our dyson will not recommend it go any one
It’s really not bad. This vacuum has out performed and lived many Dysons. I’ll never go back! They are half the price and accept coupons too
