주요 콘텐츠로 건너뛰기
Shark Flex DuoClean Brush Roll Replacement
  1. Shark Flex DuoClean Brush Roll Replacement, Garage Door: 1 단계, 이미지 2개 중 1개 Shark Flex DuoClean Brush Roll Replacement, Garage Door: 1 단계, 이미지 2개 중 2개
    • Open the garage door by sliding both of the release buttons away from you.
    • Lift off the garage door.
  2. Shark Flex DuoClean Brush Roll Replacement, Soft Roller: 2 단계, 이미지 2개 중 1개 Shark Flex DuoClean Brush Roll Replacement, Soft Roller: 2 단계, 이미지 2개 중 2개
    • Use the tab on the right side to lift out the soft roller.
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
caoimhe
회원 가입일: 10/08/18
1,007 평판
안내서 4개를 작성함
Cal Poly, Team S17-G5, White Fall 2018 Cal Poly, Team S17-G5, White Fall 2018 회원
CPSU-WHITE-F18S17G5
4 회원들
안내서 14개를 작성함
23가이드 댓글
There’s nothing blocking the soft roller in mine. I can spin it by hand. Only the regular brush roll spins. Now what?
Keith Sauer - 답글
I have the same problem. The gear that is connected to the motor that spins the soft brush roller is stripped. The shaft spins but the inside of the gear is stripped therefore it doesnt turn the soft brush roller. I cannot find the replacement part
Bill Pucher - 답글
Having this same problem
Keona Taylor -
Same here…no blockage, but won’t spin
tbridge - 답글
I also have the same problem. No blockage. The brush roller works but the soft roller does not spin.
Gina - 답글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 15
지난 30일: 58
전체 시간: 11,268
