주요 콘텐츠로 건너뛰기
Shark Flex DuoClean Drive Belt Replacement
필요한 것
  1. Shark Flex DuoClean Drive Belt Replacement, Garage Door: 1 단계, 이미지 2개 중 1개 Shark Flex DuoClean Drive Belt Replacement, Garage Door: 1 단계, 이미지 2개 중 2개
    • Open the garage door by sliding both of the release buttons away from you.
    • Lift off the garage door.
  2. Shark Flex DuoClean Drive Belt Replacement, Side Component: 2 단계, 이미지 2개 중 1개 Shark Flex DuoClean Drive Belt Replacement, Side Component: 2 단계, 이미지 2개 중 2개
    • Remove the plastic screw covering using a metal spudger by pushing the sharp side into the crevice and prying the cover out.
  3. Shark Flex DuoClean Drive Belt Replacement: 3 단계, 이미지 2개 중 1개 Shark Flex DuoClean Drive Belt Replacement: 3 단계, 이미지 2개 중 2개
    • Turn the T10 Security Torx screwdriver counterclockwise to remove the 15mm screw.
  4. Shark Flex DuoClean Drive Belt Replacement: 4 단계, 이미지 1개 중 1개
    • Use the iFixit Opening Tool to pry the side of the vacuum open.
  5. Shark Flex DuoClean Drive Belt Replacement: 5 단계, 이미지 1개 중 1개
    • Remove the side component with your hands.
  6. Shark Flex DuoClean Drive Belt Replacement, Drive Belt: 6 단계, 이미지 2개 중 1개 Shark Flex DuoClean Drive Belt Replacement, Drive Belt: 6 단계, 이미지 2개 중 2개
    • Remove old the belt from the two gears by prying it off using the metal spudger.
    • The new belt will be very tight and difficult to put back on. In order to reinstall, start with the belt on one gear, then slowly rotate the other gear, pushing on the belt and allowing it to catch the teeth.
  7. Shark Flex DuoClean Drive Belt Replacement: 7 단계, 이미지 1개 중 1개
    • Repeat on the other side of the vacuum.
결론
다른 10명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Christian Fuller
회원 가입일: 10/08/18
424 평판
안내서 3개를 작성함
Cal Poly, Team S17-G5, White Fall 2018 Cal Poly, Team S17-G5, White Fall 2018 회원
CPSU-WHITE-F18S17G5
4 회원들
안내서 14개를 작성함
10가이드 댓글
Thanks… Would have taken me forever to figure out how to get to the belts…!!!
Mike Babb - 답글
Wonderful directions and a great help, thanks. However one important factor was left out, the part number for the belts.
Dave Orr - 답글
Where to get the carpet brush belt? What would the belt size be?
Silver Dominator - 답글
Add me to the rest. I also want a belt. Does anybody ever respond to these questions?
I’m hopeful we can find a source
ShellyB
shellyb -
the belt, roller brush, entire floor unit, etc are on amazon
john smith -
댓글 쓰기
조회 통계:
지난 24시간: 4
지난 7일: 30
지난 30일: 113
전체 시간: 57,221
