소개
This repair may be necessary if the brush roll is not spinning. The belt is tight on the roll and may require some force to remove it.
필요한 것
Open the garage door by sliding both of the release buttons away from you.
Lift off the garage door.
Remove the plastic screw covering using a metal spudger by pushing the sharp side into the crevice and prying the cover out.
Turn the T10 Security Torx screwdriver counterclockwise to remove the 15mm screw.
I know it is absolutely essential to have a security bit on here to change the belt as you wouldn't want anyone accidently changing it.
Remove old the belt from the two gears by prying it off using the metal spudger.
다른 9명이 해당 안내서를 완성하였습니다.
댓글 10개
Where to get the carpet brush belt? What would the belt size be?
Add me to the rest. I also want a belt. Does anybody ever respond to these questions?
I’m hopeful we can find a source
ShellyB
shellyb -
the belt, roller brush, entire floor unit, etc are on amazon
Just been told by shark that you cant buy the belt in the UK and you have to buy the whole new head at £60!
What a rip off! Wont be buying a Shark again!
They made me buy a whole new motorized head for $99 last year. Just the duo roller doesn’t spin making it harder to push around. I still have the broken head so I think I want to take it apart and see if it’s just the belt. The new head cracked by the rear right wheel so maybe I can Frankenstein a good working one.
the belts for this are $6 on amazon part #x003p9e50v, you need a torx #10 to get into it and the sides are not easy to get off, seems a little harder then it should be to replace belts
john smith - 답글
