이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Open the garage door by sliding both of the release buttons away from you.
Lift off the garage door.
Remove the plastic screw covering using a metal spudger by pushing the sharp side into the crevice and prying the cover out.
Turn the T10 Security Torx screwdriver counterclockwise to remove the 15mm screw.
Use the nylon spudger to pry the gold, plastic cover off of the headlights.
Use wire cutters to detach the black cables from the LEDs on both sides.
Strip 1 cm off the ends of the wires, using a wire stripper.
Solder the exposed wires to the new LEDs.
