주요 콘텐츠로 건너뛰기
Shark Flex DuoClean Motherboard Replacement
필요한 것
  1. Shark Flex DuoClean Motherboard Replacement, Garage Door: 1 단계, 이미지 2개 중 1개 Shark Flex DuoClean Motherboard Replacement, Garage Door: 1 단계, 이미지 2개 중 2개
    • Open the garage door by sliding both of the release buttons away from you.
    • Lift off the garage door.
  2. Shark Flex DuoClean Motherboard Replacement, Side Component: 2 단계, 이미지 2개 중 1개 Shark Flex DuoClean Motherboard Replacement, Side Component: 2 단계, 이미지 2개 중 2개
    • Remove the plastic screw covering using a metal spudger by pushing the sharp side into the crevice and prying the cover out.
  3. Shark Flex DuoClean Motherboard Replacement: 3 단계, 이미지 2개 중 1개 Shark Flex DuoClean Motherboard Replacement: 3 단계, 이미지 2개 중 2개
    • Turn the T10 Security Torx screwdriver counterclockwise to remove the 15mm screw.
  4. Shark Flex DuoClean Motherboard Replacement: 4 단계, 이미지 1개 중 1개
    • Use the iFixit Opening Tool to pry the side of the vacuum open.
  5. Shark Flex DuoClean Motherboard Replacement: 5 단계, 이미지 1개 중 1개
    • Remove the side component with your hands.
  6. Shark Flex DuoClean Motherboard Replacement, Top Component: 6 단계, 이미지 1개 중 1개
    • Remove the four 15 mm T10 screws on the underside of the vacuum.
  7. Shark Flex DuoClean Motherboard Replacement: 7 단계, 이미지 2개 중 1개 Shark Flex DuoClean Motherboard Replacement: 7 단계, 이미지 2개 중 2개
    • Using the plastic spudger, pry the back seam of the top component to pop it off the vacuum.
  8. Shark Flex DuoClean Motherboard Replacement, Motherboard: 8 단계, 이미지 1개 중 1개
    • Remove one 15mm T10 screw from the inside left of the base of the vacuum to access the motherboard.
  9. Shark Flex DuoClean Motherboard Replacement: 9 단계, 이미지 1개 중 1개
    • Using the nylon spudger, place the curved side under the motherboard.
    • Gently pry the motherboard out of the base of the vacuum.
    • Do not use your fingers to take out the motherboard, as the bottom can be sharp.
    • The motherboard will still be connected to the base with wires.
  10. Shark Flex DuoClean Motherboard Replacement: 10 단계, 이미지 1개 중 1개
    • Desolder the motherboard wires using wire cutters.
결론
작성자
2다른 기여자 명과 함께
Samantha Mickelson
회원 가입일: 10/08/18
496 평판
안내서 4개를 작성함
Cal Poly, Team S17-G5, White Fall 2018 Cal Poly, Team S17-G5, White Fall 2018 회원
CPSU-WHITE-F18S17G5
4 회원들
안내서 14개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 10
전체 시간: 1,660
