주요 콘텐츠로 건너뛰기
Shark Flex DuoClean Suction Motor Replacement
필요한 것
  1. Shark Flex DuoClean Suction Motor Replacement, Dust Cup: 1 단계, 이미지 1/2 Shark Flex DuoClean Suction Motor Replacement, Dust Cup: 1 단계, 이미지 2/2
    • Squeeze Dust Cup release buttons on either side of the component.
    • Pull up to release Dust Cup.
  2. Shark Flex DuoClean Suction Motor Replacement, Suction Motor: 2 단계, 이미지 1/1
    • Remove the five 15 mm screws by twisting counterclockwise with a T10 Torx screwdriver.
  3. Shark Flex DuoClean Suction Motor Replacement: 3 단계, 이미지 1/1
    • Use the iFixit opening tool to remove the top component.
  4. Shark Flex DuoClean Suction Motor Replacement: 4 단계, 이미지 1/1
    • Remove the two 15mm screws by twisting counterclockwise using the T10 Torx screwdriver.
  5. Shark Flex DuoClean Suction Motor Replacement: 5 단계, 이미지 1/1
    • Remove the two 15 mm screws by twisting counterclockwise with a T10 Torx screwdriver.
  6. Shark Flex DuoClean Suction Motor Replacement: 6 단계, 이미지 1/1
    • Remove the two 15 mm screws holding the motor cover by twisting counterclockwise with a T10 Torx screwdriver.
  7. Shark Flex DuoClean Suction Motor Replacement: 7 단계, 이미지 1/1
    • Cut the zip ties holding the motor using the wire cutter.
  8. Shark Flex DuoClean Suction Motor Replacement: 8 단계, 이미지 1/1
    • Cut the wires using the wire cutters to completely remove the motor.
    • For reassembly, use the soldering guide in the Introduction.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Christian Fuller
회원 가입일: 10/08/18
420 평판
안내서 3개 작성하였습니다
Cal Poly, Team S17-G5, White Fall 2018 Cal Poly, Team S17-G5, White Fall 2018 회원
CPSU-WHITE-F18S17G5
4 회원들
안내서 14개 작성하였습니다
댓글 한 개
how i need to know how to re connect the wires on replacing a new motor, my model is similar HV321.
andrea - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 3
30일 전: 22
전체 시간: 3,482
