주요 콘텐츠로 건너뛰기
Shark ION Robot 750 Motor Replacement
필요한 것
  1. Shark ION Robot 750 Motor Replacement, Outer Shell: 1 단계, 이미지 3개 중 1개 Shark ION Robot 750 Motor Replacement, Outer Shell: 1 단계, 이미지 3개 중 2개 Shark ION Robot 750 Motor Replacement, Outer Shell: 1 단계, 이미지 3개 중 3개
    • Make sure the device is completely powered off before working.
    • Flip over the vacuum on a flat and uncluttered service with the bottom facing upwards.
    • Remove all seven 9.1mm Torx T15 screws from the device’s front bumper.
    • Remove the nine 9.1mm Torx T6 bolts from outer shell.
  2. Shark ION Robot 750 Motor Replacement: 2 단계, 이미지 2개 중 1개 Shark ION Robot 750 Motor Replacement: 2 단계, 이미지 2개 중 2개
    • Slightly pull front bumper to expose internal wiring.
    • Unplug the device’s front bumper wiring and completely remove front bumper.
  3. Shark ION Robot 750 Motor Replacement: 3 단계, 이미지 2개 중 1개 Shark ION Robot 750 Motor Replacement: 3 단계, 이미지 2개 중 2개
    • Remove the four 9.5mm Torx T6 bolts on the yellow brush frame.
    • Gently depress the two tabs on the frame, then lift the frame to remove it.
  4. Shark ION Robot 750 Motor Replacement: 4 단계, 이미지 2개 중 1개 Shark ION Robot 750 Motor Replacement: 4 단계, 이미지 2개 중 2개
    • Pick up the brush and remove it from the vacuum.
    • Push the brush to your right and lift it.
  5. Shark ION Robot 750 Motor Replacement: 5 단계, 이미지 3개 중 1개 Shark ION Robot 750 Motor Replacement: 5 단계, 이미지 3개 중 2개 Shark ION Robot 750 Motor Replacement: 5 단계, 이미지 3개 중 3개
    • Press and hold the dust bin removal button to slide out the dust bin.
  6. Shark ION Robot 750 Motor Replacement: 6 단계, 이미지 1개 중 1개
    • Lift the outer shell to expose the Shark’s interior.
  7. Shark ION Robot 750 Motor Replacement, Motor: 7 단계, 이미지 2개 중 1개 Shark ION Robot 750 Motor Replacement, Motor: 7 단계, 이미지 2개 중 2개
    • Be sure to disconnect any source of power related to your vacuum for safety purposes.
    • Remove the bolt to detach the motor by using the Phillips #0 screwdriver.
    • The motor is connected to the motherboard by this group of wires. Gently pull on the white plug to disconnect the wires.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
corieon downing
회원 가입일: 09/13/23
190 평판
안내서 2개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 29
전체 시간: 585
