주요 콘텐츠로 건너뛰기
Shark ION Robot 750 Sensor Replacement
필요한 것
  1. Shark ION Robot 750 Sensor Replacement, Outer Shell: 1 단계, 이미지 3개 중 1개 Shark ION Robot 750 Sensor Replacement, Outer Shell: 1 단계, 이미지 3개 중 2개 Shark ION Robot 750 Sensor Replacement, Outer Shell: 1 단계, 이미지 3개 중 3개
    • Make sure the device is completely powered off before working.
    • Flip over the vacuum on a flat and uncluttered service with the bottom facing upwards.
    • Remove all seven 9.1mm Torx T15 screws from the device’s front bumper.
    • Remove the nine 9.1mm Torx T6 bolts from outer shell.
  2. Shark ION Robot 750 Sensor Replacement: 2 단계, 이미지 2개 중 1개 Shark ION Robot 750 Sensor Replacement: 2 단계, 이미지 2개 중 2개
    • Slightly pull front bumper to expose internal wiring.
    • Unplug the device’s front bumper wiring and completely remove front bumper.
  3. Shark ION Robot 750 Sensor Replacement: 3 단계, 이미지 2개 중 1개 Shark ION Robot 750 Sensor Replacement: 3 단계, 이미지 2개 중 2개
    • Remove the four 9.5mm Torx T6 bolts on the yellow brush frame.
    • Gently depress the two tabs on the frame, then lift the frame to remove it.
  4. Shark ION Robot 750 Sensor Replacement: 4 단계, 이미지 2개 중 1개 Shark ION Robot 750 Sensor Replacement: 4 단계, 이미지 2개 중 2개
    • Pick up the brush and remove it from the vacuum.
    • Push the brush to your right and lift it.
  5. Shark ION Robot 750 Sensor Replacement: 5 단계, 이미지 3개 중 1개 Shark ION Robot 750 Sensor Replacement: 5 단계, 이미지 3개 중 2개 Shark ION Robot 750 Sensor Replacement: 5 단계, 이미지 3개 중 3개
    • Press and hold the dust bin removal button to slide out the dust bin.
  6. Shark ION Robot 750 Sensor Replacement: 6 단계, 이미지 1개 중 1개
    • Lift the outer shell to expose the Shark’s interior.
  7. Shark ION Robot 750 Sensor Replacement, Sensors: 7 단계, 이미지 2개 중 1개 Shark ION Robot 750 Sensor Replacement, Sensors: 7 단계, 이미지 2개 중 2개
    • Use a Phillips #1 screwdriver to remove the four 11.5 mm screws from the main circuit board.
  8. Shark ION Robot 750 Sensor Replacement: 8 단계, 이미지 2개 중 1개 Shark ION Robot 750 Sensor Replacement: 8 단계, 이미지 2개 중 2개
    • Use a spudger or tweezers to disconnect the white cable connector from the socket on the motherboard.
    • Detach the 17 connectors from the motherboard.
    • For helpful details on disconnecting different types of connectors, check out the Recognizing & Disconnecting Cable Connectors guide.
    • Don't pull on the cables as they might get damaged and affect the function of the vacuum.
  9. Shark ION Robot 750 Sensor Replacement: 9 단계, 이미지 1개 중 1개
    • Pull the outer case away from the robot vacuum to reveal the sensors.
  10. Shark ION Robot 750 Sensor Replacement: 10 단계, 이미지 3개 중 1개 Shark ION Robot 750 Sensor Replacement: 10 단계, 이미지 3개 중 2개 Shark ION Robot 750 Sensor Replacement: 10 단계, 이미지 3개 중 3개
    • Insert the tweezer between the sensor lid and lower shell.
    • Gently lift each sensor up and out using the tweezer.
결론
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
작성자
1다른 기여자 명과 함께
Asmitha D
회원 가입일: 02/08/24
109 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 10
지난 30일: 33
전체 시간: 472
