주요 콘텐츠로 건너뛰기
Shark ION Robot R75 Drive Wheel Assembly Replacement
필요한 것
  1. Shark ION Robot R75 Drive Wheel Assembly Replacement, Battery: 1 단계, 이미지 3개 중 1개 Shark ION Robot R75 Drive Wheel Assembly Replacement, Battery: 1 단계, 이미지 3개 중 2개 Shark ION Robot R75 Drive Wheel Assembly Replacement, Battery: 1 단계, 이미지 3개 중 3개
    • Make sure the robot is shut off by pressing the power button on top.
    • Flip the R75 over so that the underside is facing up.
    • Using a Phillips #1 screwdriver, remove the 4mm screw in the battery cover.
    • Remove the battery cover.
  2. Shark ION Robot R75 Drive Wheel Assembly Replacement: 2 단계, 이미지 3개 중 1개 Shark ION Robot R75 Drive Wheel Assembly Replacement: 2 단계, 이미지 3개 중 2개 Shark ION Robot R75 Drive Wheel Assembly Replacement: 2 단계, 이미지 3개 중 3개
    • Be careful when removing the battery, as it will still be connected to a wire.
    • Slowly pull the white tabs outward to remove the battery.
  3. Shark ION Robot R75 Drive Wheel Assembly Replacement: 3 단계, 이미지 2개 중 1개 Shark ION Robot R75 Drive Wheel Assembly Replacement: 3 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Be careful when removing the connector, as the part can break if too much force is used.
    • Push down on the tab of the battery connector using a set of tweezers and pull the connector away from the robot to free the wire.
    • Remove the battery from the device.
  4. Shark ION Robot R75 Drive Wheel Assembly Replacement, Drive Wheel Assembly: 4 단계, 이미지 1개 중 1개
    • Flip the R75 to its underside.
    • Make sure the R75 is shut off.
    • For extra security, disconnect the battery by following the prerequisite guide.
  5. Shark ION Robot R75 Drive Wheel Assembly Replacement: 5 단계, 이미지 3개 중 1개 Shark ION Robot R75 Drive Wheel Assembly Replacement: 5 단계, 이미지 3개 중 2개 Shark ION Robot R75 Drive Wheel Assembly Replacement: 5 단계, 이미지 3개 중 3개
    • Using a Torx T15 screwdriver, remove the five screws from the drive wheel assembly.
    • Carefully lift the drive wheel assembly from the wheel well by gently pulling up on the wheel.
    • The assembly will still be connected to the motherboard via a cable, so be sure not to pull so hard that the cable rips.
  6. Shark ION Robot R75 Drive Wheel Assembly Replacement: 6 단계, 이미지 3개 중 1개 Shark ION Robot R75 Drive Wheel Assembly Replacement: 6 단계, 이미지 3개 중 2개 Shark ION Robot R75 Drive Wheel Assembly Replacement: 6 단계, 이미지 3개 중 3개
    • Flip the wheel assembly over and disconnect the cable connector on its underside.
    • Remove the drive wheel assembly.
    • Repeat this process for the other side if necessary.
결론
다른 3명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Andrew Lowy
회원 가입일: 01/25/20
599 평판
안내서 4개를 작성함
6가이드 댓글
Where I can buy the Shark ION Robot R75 Drive Wheel Assembly Replacement?
Thanks for your help!
xoxolo - 답글
Do you know what the drive wheel motor cable is (see Step 6)? It's a 6 pin to 5 pin and the grooves are on the thin side and pitch of ~1.4mm. Possible a JST ZH?
Seth T - 답글
I appreciate the step-by-step instructions with pictures... this was very helpful. However, my rv750 doesn't have the screws by the wheel assembly.
I've removed the screws, but it appears that I will need to separate the bottom from the top to access the wheel assemblies. Do you have a step=by step for the rv750 that has the wheel assembly enclosed?
RandiB - 답글
The right wheel ass has a small gear striped inside, can you buy the small gears to repair the wheel drive?
Jerry Rotenberry - 답글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 4
지난 30일: 57
전체 시간: 10,474
