주요 콘텐츠로 건너뛰기
Shark ION Robot R75 Main Brush Replacement
  1. Shark ION Robot R75 Main Brush Replacement, Main Brush: 1 단계, 이미지 1/1
    • Push on the two tabs on the edge of the main brush cover and pull up to remove the cover.
  2. Shark ION Robot R75 Main Brush Replacement: 2 단계, 이미지 1/1
    • Pull the main brush slightly to the right to remove it from the compartment.
  3. Shark ION Robot R75 Main Brush Replacement: 3 단계, 이미지 1/2 Shark ION Robot R75 Main Brush Replacement: 3 단계, 이미지 2/2
    • Remove the rubber end cap indicated by the red circle.
    • This step is not needed for a replacement. However, it is important for maintenance. Hair will build up in this area over time, and will cause error messages to pop up, as well as stopping the R75 from cleaning and moving.
    • Inspect this component at least every six months. This time may be less if you have animals.
결론
Kyle Wilbourn
회원 가입일: 01/25/20
513 평판
안내서 4개 작성하였습니다
댓글 한 개
My shark ion stopped working after about 6 months and it started giving an error on the brush. I cleaned my vacuum pretty regularly, at least once a week. I ordered a replacement brush and it still hasn't fixed it. Do you have any other suggestions?
Tina Hicks - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 11
30일 전: 74
전체 시간: 2,580
