주요 콘텐츠로 건너뛰기
Shark ION Robot R75 Side Brush Replacement
필요한 것
  1. Shark ION Robot R75 Side Brush Replacement, Side Brush: 1 단계, 이미지 1/3 Shark ION Robot R75 Side Brush Replacement, Side Brush: 1 단계, 이미지 2/3 Shark ION Robot R75 Side Brush Replacement, Side Brush: 1 단계, 이미지 3/3
    • Grab the side brushes by the plastic tab at the base of the bristles, and gently lift up.
    • It's recommended to clean the area with a dry microfiber cloth during replacement, as debris can collect beneath the brush during use.
결론
Kyle Wilbourn
회원 가입일: 01/25/20
513 평판
안내서 4개 작성하였습니다
댓글 2개
I have removed/lost my screw that went inside the side brush. Do you have screw size recommendation to replace it? Shark doesn't sell them and says the brush may fall off if I don't have my screw. Is it guaranteed that Phillips #1 Screwdriver would be able to remove screws? I have tried all types of screwdrivers and haven't found one to remove the other screw to take it to the store to find the right size to replace what I am missing.
Kell S - 답글
Our Shark AV1002AE needs a Torx T-9 to remove the screw. However we have not found a replacement screw or insert
Kathy - 답글
댓글 쓰기
조회 통계:
24 시간 전: 6
7일 전: 34
30일 전: 162
전체 시간: 5,813
