주요 콘텐츠로 건너뛰기
Shark ION Robot S87 Bumper Replacement
필요한 것
  1. Shark ION Robot S87 Bumper Replacement, Bumper: 1 단계, 이미지 1개 중 1개
    • Flip the Shark ION Robot S87 on its underside so that the bumper and its screws are facing upwards.
    • Use a Hex 2mm screwdriver to remove the five 8mm screws from the bumper.
  2. Shark ION Robot S87 Bumper Replacement: 2 단계, 이미지 3개 중 1개 Shark ION Robot S87 Bumper Replacement: 2 단계, 이미지 3개 중 2개 Shark ION Robot S87 Bumper Replacement: 2 단계, 이미지 3개 중 3개
    • Once all screws have been removed lift the thin side of the bumper upwards to remove it from the robot.
    • Lift the robot up so that the larger part of the bumper stays on the floor and is removed.
    • Once both pieces of the bumper have been removed, you can place the robot back down.
  3. Shark ION Robot S87 Bumper Replacement: 3 단계, 이미지 1개 중 1개
    • Check all sensors and remove any that may have debris in front of it.
    • You may also swap out the bumper for another depending on whether or not it is broken.
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Adeel Ahmad
회원 가입일: 01/14/20
256 평판
안내서 2개를 작성함
York University, Team S1-G7, Woodhouse Winter 2020 York University, Team S1-G7, Woodhouse Winter 2020 회원
YORK-WOODHOUSE-W20S1G7
3 회원들
안내서 12개를 작성함
1가이드 댓글
Where can I buy a new bumper?
Lacy - 답글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 9
지난 30일: 78
전체 시간: 13,514
