주요 콘텐츠로 건너뛰기
Shark IONFlex 2X Soft Brush Roll Replacement
  1. Shark IONFlex 2X Soft Brush Roll Replacement, Soft Brush Roll: 1 단계, 이미지 1/1
    • Press and slide the access brush roll buttons towards the "Access Brush Roll" printing on casing.
  2. Shark IONFlex 2X Soft Brush Roll Replacement: 2 단계, 이미지 1/1
    • Lift plastic casing upward and off of the top of the floor unit. Place off to the side.
  3. Shark IONFlex 2X Soft Brush Roll Replacement: 3 단계, 이미지 1/1
    • Pull the red Pull tab that is located on the right side of the soft brush roll away from the front of the vacuum and place the soft brush roll to the side.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Eric Dean
회원 가입일: 10/14/18
503 평판
안내서 2개 작성하였습니다
댓글 한 개
I’m trying to fix the plastic gear that the roller fits onto. It’s broken and I think it needs to be disassembled more and need replacement parts. Model # IF200W. Any advice??
Anthony - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 8
30일 전: 24
전체 시간: 2,609
