소개
This guide will go over how to remove the battery in the Shark IQ AV993 robot vacuum. There are no requirements in order to replace the battery just follow the guide and you'll be okay. Be careful with all the parts you replace make sure not to tug, pull and snap any pieces as they will break and be unfixable. This replacement may be needed if your Shark IQ AV993 won't turn on, or is having a hard time charging.
필요한 것
다른 2명이 해당 안내서를 완성하였습니다.
