소개
If the handle for your Steam Pocket Mop gets loose and falls off, or if you would like to remove the handle for easy storage, use this guide to walk you through the process. You will need a Phillips #2 screwdriver for this replacement.
필요한 것
거의 끝나갑니다!
To disassemble your device, follow these instructions in reverse order.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
