주요 콘텐츠로 건너뛰기
Shark Lift-Away Professional Steam Pocket Mop Handle Replacement
필요한 것
  1. Shark Lift-Away Professional Steam Pocket Mop Handle Replacement, Mop Handle: 1 단계, 이미지 1/1
    • Turn off the Steam Pocket Mop and unplug it from the wall.
    • Be sure that any water in the water tank cools before proceeding.
  2. Shark Lift-Away Professional Steam Pocket Mop Handle Replacement: 2 단계, 이미지 1/1
    • Place the Steam Pocket Mop face down on a flat surface.
    • Take note of the placement of the handle; the side labelled "front" should should face forward.
  3. Shark Lift-Away Professional Steam Pocket Mop Handle Replacement: 3 단계, 이미지 1/3 Shark Lift-Away Professional Steam Pocket Mop Handle Replacement: 3 단계, 이미지 2/3 Shark Lift-Away Professional Steam Pocket Mop Handle Replacement: 3 단계, 이미지 3/3
    • Remove the screw located underneath the cord holder.
    • Turn the screwdriver counter-clockwise to loosen the screw from its slot.
    • This is a long screw and will take time to remove.
결론
To disassemble your device, follow these instructions in reverse order.
다른 한 분이 해당 안내서를 완성하였습니다.
Nancy K Do
회원 가입일: 10/17/18
165 평판
안내서 1개 작성함
UW Tacoma, Team S1-G3, Rose Fall 2018 UW Tacoma, Team S1-G3, Rose Fall 2018 회원
UWT-ROSE-F18S1G3
4 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 7
30일 전: 31
전체 시간: 6,234
