주요 콘텐츠로 건너뛰기
Shark Lift-Away Professional Steam Pocket Mop Pad Replacement
  1. Shark Lift-Away Professional Steam Pocket Mop Pad  Replacement, Mop Pad: 1 단계, 이미지 1/2 Shark Lift-Away Professional Steam Pocket Mop Pad  Replacement, Mop Pad: 1 단계, 이미지 2/2
    • Turn off the Steam Pocket Mop and unplug it from the wall.
    • Be sure that any water in the water tank cools before proceeding.
  2. Shark Lift-Away Professional Steam Pocket Mop Pad  Replacement: 2 단계, 이미지 1/3 Shark Lift-Away Professional Steam Pocket Mop Pad  Replacement: 2 단계, 이미지 2/3 Shark Lift-Away Professional Steam Pocket Mop Pad  Replacement: 2 단계, 이미지 3/3
    이 단계에 사용된 도구:
    Microfiber Cleaning Cloths
    $3.99
    구매
    • Release the quick fasteners from the top of the cloth using the loops.
    • Slide the cloth off from around the mop head.
    • Our mop pad was missing, so we used a similar microfiber cloth in our images.
결론
Repeat this process every time you need to replace your mop pad.
Rachel Howe
회원 가입일: 10/17/18
261 평판
안내서 2개 작성하였습니다
UW Tacoma, Team S1-G3, Rose Fall 2018 UW Tacoma, Team S1-G3, Rose Fall 2018 회원
UWT-ROSE-F18S1G3
4 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 4
30일 전: 19
전체 시간: 1,325
