주요 콘텐츠로 건너뛰기
Shark Matrix RV2310 Wheel Assembly Replacement
필요한 것
  1. Shark Matrix RV2310 Wheel Assembly Replacement, Battery: 1 단계, 이미지 3개 중 1개 Shark Matrix RV2310 Wheel Assembly Replacement, Battery: 1 단계, 이미지 3개 중 2개 Shark Matrix RV2310 Wheel Assembly Replacement, Battery: 1 단계, 이미지 3개 중 3개
    • Remove the two 11 mm Phillips screws holding the battery plate in place.
    • Remove the battery plate.
  2. Shark Matrix RV2310 Wheel Assembly Replacement: 2 단계, 이미지 3개 중 1개 Shark Matrix RV2310 Wheel Assembly Replacement: 2 단계, 이미지 3개 중 2개 Shark Matrix RV2310 Wheel Assembly Replacement: 2 단계, 이미지 3개 중 3개
    • Remove the battery from the compartment.
    • Disconnect the electrical cable connection from the battery to the robot.
  3. Shark Matrix RV2310 Wheel Assembly Replacement, Wheel Assembly: 3 단계, 이미지 2개 중 1개 Shark Matrix RV2310 Wheel Assembly Replacement, Wheel Assembly: 3 단계, 이미지 2개 중 2개
    • Remove the five 11 mm Phillips screws holding the wheel assembly in place.
    • Make sure the device's battery has been fully removed from the device before proceeding. Failure to do so could potentially result in minor/moderate injuries.
  4. Shark Matrix RV2310 Wheel Assembly Replacement: 4 단계, 이미지 1개 중 1개
    • Lift the wheel assembly out of the vacuum.
    • Do not pull or tug too hard on the wheel when lifting it, as there is a wire connection between the wheel and the motherboard.
  5. Shark Matrix RV2310 Wheel Assembly Replacement: 5 단계, 이미지 1개 중 1개
    • Undo the wire connection between the motherboard and the wheel assembly by gently pulling the wire out from the wheel assembly's connector.
결론
작성자
2다른 기여자 명과 함께
Joshua Correia
회원 가입일: 03/22/24
631 평판
안내서 5개를 작성함
UMass Dartmouth, Team 6-4, Botvin Spring 2024 UMass Dartmouth, Team 6-4, Botvin Spring 2024 회원
UMASSD-BOTVIN-S24S6G4
2 회원들
안내서 5개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 15
지난 30일: 59
전체 시간: 555
