소개
The roller brush helps to pick up dirt deep in the carpet or stuck to the floor. If the roller brush is no longer rotating, you may have to remove it and clean or replace it. Follow these steps to remove the roller brush.
필요한 것
Lift the latches on both sides of the vacuum to release the dust canister.
Remove the dust canister from the vacuum by lifting it up.
다른 9명이 해당 안내서를 완성하였습니다.
댓글 한 개
FOR SOME MODELS - THE BRUSH WILL NOT OPERATE IN AN UPRIGHT POSITION.
Shark navigator 350-353 series - if you have cleaned the roller and it doesn't work, TILT THE HANDLE BACK then try.
