주요 콘텐츠로 건너뛰기
Shark Navigator Freestyle SV1106 Battery Pack Replacement
필요한 것
  1. Shark Navigator Freestyle SV1106 Battery Pack Replacement, Battery Pack: 1 단계, 이미지 1/1
    • Turn the device over to reveal the bottom of the motorized brush head.
  2. Shark Navigator Freestyle SV1106 Battery Pack Replacement: 2 단계, 이미지 1/2 Shark Navigator Freestyle SV1106 Battery Pack Replacement: 2 단계, 이미지 2/2
    • Slide the latch next to the panel upwards into the unlocked position.
  3. Shark Navigator Freestyle SV1106 Battery Pack Replacement: 3 단계, 이미지 1/1
    • Slide the panel to the right to reveal the battery.
  4. Shark Navigator Freestyle SV1106 Battery Pack Replacement: 4 단계, 이미지 1/2 Shark Navigator Freestyle SV1106 Battery Pack Replacement: 4 단계, 이미지 2/2
    • Pull the battery from the vacuum.
  5. Shark Navigator Freestyle SV1106 Battery Pack Replacement: 5 단계, 이미지 1/2 Shark Navigator Freestyle SV1106 Battery Pack Replacement: 5 단계, 이미지 2/2
    • Disconnect the battery from the vacuum by pinching the white latch and pulling the two pieces apart.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Zachary Liu
회원 가입일: 01/24/18
604 평판
안내서 5개 작성하였습니다
Cal Poly, Team S1-G5, Livingston Winter 2018 Cal Poly, Team S1-G5, Livingston Winter 2018 회원
CPSU-LIVINGSTON-W18S1G5
3 회원들
안내서 10개 작성하였습니다
댓글 8개
How much is the part for the shark
sumi49 - 답글
My Shark SV1106 doesn’t stay on very long. One episode you turn it on it immediately turns off. So what is the issue?
jklab23 - 답글
How much is a battery pack?
ridgeite145 - 답글
Items OrderedPrice1 of: 10.8V 3000mah Battery for Shark XBT1106N SV1110 SV1106N SV1110N SV11O6N SV116N Freestyle Navigator Cordless Stick Vacuum
Sold by: Areotek Direct (seller profile)
Condition: New
James Mayoral -
How much is a new battery pack for replacement
ridgeite145 - 답글
댓글 쓰기
조회 통계:
24 시간 전: 4
7일 전: 16
30일 전: 67
전체 시간: 10,758
