주요 콘텐츠로 건너뛰기
Shark Navigator Freestyle SV1106 Roller Brush Replacement
필요한 것
  1. Shark Navigator Freestyle SV1106 Roller Brush Replacement, Roller Brush: 1 단계, 이미지 1/2 Shark Navigator Freestyle SV1106 Roller Brush Replacement, Roller Brush: 1 단계, 이미지 2/2
    • Remove the black rubber band from the roller brush
    • In most models there will be a plastic cover over the rubber band. You will use the quarter to twist the latch and take off the cover
  2. Shark Navigator Freestyle SV1106 Roller Brush Replacement: 2 단계, 이미지 1/3 Shark Navigator Freestyle SV1106 Roller Brush Replacement: 2 단계, 이미지 2/3 Shark Navigator Freestyle SV1106 Roller Brush Replacement: 2 단계, 이미지 3/3
    • Use the bristles to pull the end of the brush that was connected to the belt away from the vacuum.
  3. Shark Navigator Freestyle SV1106 Roller Brush Replacement: 3 단계, 이미지 1/3 Shark Navigator Freestyle SV1106 Roller Brush Replacement: 3 단계, 이미지 2/3 Shark Navigator Freestyle SV1106 Roller Brush Replacement: 3 단계, 이미지 3/3
    • Slide the roller belt off of the roller brush and pull the roller away from the motorized brush.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Zachary Liu
회원 가입일: 01/24/18
604 평판
안내서 5개 작성하였습니다
Cal Poly, Team S1-G5, Livingston Winter 2018 Cal Poly, Team S1-G5, Livingston Winter 2018 회원
CPSU-LIVINGSTON-W18S1G5
3 회원들
안내서 10개 작성하였습니다
댓글 3개
but where can I buy the brush for model SV1106?
ellenmccarthycalif - 답글
Replace the brush? They are not available for purchase.
Ken Codeglia - 답글
If only you could buy a brush besides second hand on eBay…
isaac.a.brown - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 21
전체 시간: 2,977
