주요 콘텐츠로 건너뛰기
Shark Navigator HEPA Filter Replacement
  1. Shark Navigator HEPA Filter Replacement, HEPA Filter: 1 단계, 이미지 1/1
    • On the front of the vacuum, locate the latch on the bottom of the front vent.
  2. Shark Navigator HEPA Filter Replacement: 2 단계, 이미지 1/1
    • Press up on the latch and remove the front vent
  3. Shark Navigator HEPA Filter Replacement: 3 단계, 이미지 1/1
    • Lift the HEPA filter out of the vacuum
결론
다른 3명이 해당 안내서를 완성하였습니다.
Heather Shanks
회원 가입일: 03/25/15
259 평판
안내서 1개 작성함
UMass Dartmouth, Team 5-4, Kish Spring 2015 UMass Dartmouth, Team 5-4, Kish Spring 2015 회원
UMASSD-KISH-S15S5G4
4 회원들
안내서 16개 작성하였습니다
댓글 2개
the taking out worked great but putting the new one back in is impossible.......will not fit i will not buy a new vac because of this........
lillian kresge - 답글
this is the second filter that i have purchased and it is the same...does not fit properly i could use a hammer to it?????
lillian kresge - 답글
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 17
30일 전: 69
전체 시간: 12,012
