주요 콘텐츠로 건너뛰기
Shark Navigator Lift-Away Deluxe NV360 Foam and Felt Filters Replacement
  1. Shark Navigator Lift-Away Deluxe NV360 Foam and Felt Filters Replacement, Foam and Felt Filters: 1 단계, 이미지 1/1
    • Locate the latches on the side of the dust cup, the clear plastic chamber in the center of the vacuum.
  2. Shark Navigator Lift-Away Deluxe NV360 Foam and Felt Filters Replacement: 2 단계, 이미지 1/3 Shark Navigator Lift-Away Deluxe NV360 Foam and Felt Filters Replacement: 2 단계, 이미지 2/3 Shark Navigator Lift-Away Deluxe NV360 Foam and Felt Filters Replacement: 2 단계, 이미지 3/3
    • Pull the bottom of the latch with your hand in an upward direction.
    • Lift the top of the latch up and away from the dust cup using your hand.
    • Repeat the above steps with the latch on the other side of the dust cup.
  3. Shark Navigator Lift-Away Deluxe NV360 Foam and Felt Filters Replacement: 3 단계, 이미지 1/2 Shark Navigator Lift-Away Deluxe NV360 Foam and Felt Filters Replacement: 3 단계, 이미지 2/2
    • Lift the dust cup up and away by its handle on the top with your hands.
  4. Shark Navigator Lift-Away Deluxe NV360 Foam and Felt Filters Replacement: 4 단계, 이미지 1/3 Shark Navigator Lift-Away Deluxe NV360 Foam and Felt Filters Replacement: 4 단계, 이미지 2/3 Shark Navigator Lift-Away Deluxe NV360 Foam and Felt Filters Replacement: 4 단계, 이미지 3/3
    • Lift the foam filter up, out, and away with your hands.
  5. Shark Navigator Lift-Away Deluxe NV360 Foam and Felt Filters Replacement: 5 단계, 이미지 1/3 Shark Navigator Lift-Away Deluxe NV360 Foam and Felt Filters Replacement: 5 단계, 이미지 2/3 Shark Navigator Lift-Away Deluxe NV360 Foam and Felt Filters Replacement: 5 단계, 이미지 3/3
    • Lift the felt filter up, out, and away with your hands by the tab on the top.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Pramika Kumar
회원 가입일: 09/30/17
255 평판
안내서 1개 작성함
Cal Poly, Team S15-G2, Livingston Fall 2017 Cal Poly, Team S15-G2, Livingston Fall 2017 회원
CPSU-LIVINGSTON-F17S15G2
3 회원들
안내서 14개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 6
30일 전: 36
전체 시간: 4,926
