주요 콘텐츠로 건너뛰기
Shark Navigator Lift-Away Deluxe NV360 HEPA Filter Replacement
  1. Shark Navigator Lift-Away Deluxe NV360 HEPA Filter Replacement, HEPA Filter: 1 단계, 이미지 1/3 Shark Navigator Lift-Away Deluxe NV360 HEPA Filter Replacement, HEPA Filter: 1 단계, 이미지 2/3 Shark Navigator Lift-Away Deluxe NV360 HEPA Filter Replacement, HEPA Filter: 1 단계, 이미지 3/3
    • Press the latch below the HEPA filter on the bottom of the front body of the vacuum and pull outwards with your hands.
    • Pull the grey and blue plastic cover down and away with your hands.
  2. Shark Navigator Lift-Away Deluxe NV360 HEPA Filter Replacement: 2 단계, 이미지 1/3 Shark Navigator Lift-Away Deluxe NV360 HEPA Filter Replacement: 2 단계, 이미지 2/3 Shark Navigator Lift-Away Deluxe NV360 HEPA Filter Replacement: 2 단계, 이미지 3/3
    • Pull the HEPA filter out by the grey plastic tab in the middle of the grate with your hands.
    • Wiggle it around as you are pulling if the HEPA filter is not coming out easily.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Elena Postupalskaya
회원 가입일: 10/02/17
1,177 평판
안내서 6개 작성하였습니다
Cal Poly, Team S15-G2, Livingston Fall 2017 Cal Poly, Team S15-G2, Livingston Fall 2017 회원
CPSU-LIVINGSTON-F17S15G2
3 회원들
안내서 14개 작성하였습니다
댓글 한 개
I bought two different HEPA filters for the front, and they just blow off. What is the part with the tab that you push down to get the filter out? Is that an extra part cuz I don't even have that.
Kelly Kusemamuriwo - 답글
댓글 쓰기
조회 통계:
24 시간 전: 5
7일 전: 18
30일 전: 101
전체 시간: 6,300
