주요 콘텐츠로 건너뛰기
Shark Navigator Lift-Away Upright UV725BXBRN Brush Roll Replacement
필요한 것
  1. Shark Navigator Lift-Away Upright UV725BXBRN Brush Roll Replacement, Self Cleaning Brush Roll: 1 단계, 이미지 1/2 Shark Navigator Lift-Away Upright UV725BXBRN Brush Roll Replacement, Self Cleaning Brush Roll: 1 단계, 이미지 2/2
    • Make sure to turn off the vacuum and unplug it from the outlet.
  2. Shark Navigator Lift-Away Upright UV725BXBRN Brush Roll Replacement: 2 단계, 이미지 1/3 Shark Navigator Lift-Away Upright UV725BXBRN Brush Roll Replacement: 2 단계, 이미지 2/3 Shark Navigator Lift-Away Upright UV725BXBRN Brush Roll Replacement: 2 단계, 이미지 3/3
    • Push down on the bottom of the vacuum so it can dangle.
    • Using a flathead screwdriver to turn the lock counterclockwise, then open the cover to access the brush roll.
  3. Shark Navigator Lift-Away Upright UV725BXBRN Brush Roll Replacement: 3 단계, 이미지 1/1
    • Clear out any debris and close up the bottom using the previous steps.
    • Unfortunately, the new technology implemented in the self-cleaning brush roll prevents it from being detachable. You have a guaranteed 5-year warranty from Shark. Contact them using this link.
결론
To reassemble your device, follow these instructions in reverse order. Also if your self-cleaning brush roll doesn’t work at all. You have a 5-year warranty with the manufacture and will be replaced. Go to this link and they will help you immediately. https://support.sharkclean.com/hc/en-us/...
다른 2명이 해당 안내서를 완성하였습니다.
첨부 문서
Nadir Abdusemed
회원 가입일: 10/12/21
124 평판
안내서 1개 작성함
CSU Los Angeles, Team 11-5, Grodsky Fall 2021 CSU Los Angeles, Team 11-5, Grodsky Fall 2021 회원
CSULA-GRODSKY-F21S11G5
1 회원
안내서 1개 작성하였습니다
댓글 한 개
The brush roller and placement of it is filthy with dog hair and dirt needs to be scraped out. There must be a way to remove it to clean without having to send it to the manufacturer
Nana - 답글
댓글 쓰기
조회 통계:
24 시간 전: 7
7일 전: 41
30일 전: 161
전체 시간: 4,077
