주요 콘텐츠로 건너뛰기
Shark Navigator Lightweight Upright Head Shell Replacement
필요한 것
  1. Shark Navigator Lightweight Upright Head Shell Replacement, Head Shell: 1 단계, 이미지 2개 중 1개 Shark Navigator Lightweight Upright Head Shell Replacement, Head Shell: 1 단계, 이미지 2개 중 2개
    • Detach the hose connected on the bottom of the vacuum by pulling it out of the casing.
  2. Shark Navigator Lightweight Upright Head Shell Replacement: 2 단계, 이미지 2개 중 1개 Shark Navigator Lightweight Upright Head Shell Replacement: 2 단계, 이미지 2개 중 2개
    • Lay the vacuum on its side.
    • Press in the black, rubberish button located on the back of the vacuum to detach the vacuum head from the body.
  3. Shark Navigator Lightweight Upright Head Shell Replacement: 3 단계, 이미지 1개 중 1개
    • Flip over the vacuum head so the brush head is facing up.
  4. Shark Navigator Lightweight Upright Head Shell Replacement: 4 단계, 이미지 3개 중 1개 Shark Navigator Lightweight Upright Head Shell Replacement: 4 단계, 이미지 3개 중 2개 Shark Navigator Lightweight Upright Head Shell Replacement: 4 단계, 이미지 3개 중 3개
    • Remove the small front wheels with a metal spudger by inserting the metal spudger in front of the wheel and slowly prying up. This will free the wheel and reveal the screw beneath it.
    • Repeat this for the other wheel.
  5. Shark Navigator Lightweight Upright Head Shell Replacement: 5 단계, 이미지 2개 중 1개 Shark Navigator Lightweight Upright Head Shell Replacement: 5 단계, 이미지 2개 중 2개
    • Remove the two 18mm screws with a JIS 1 screwdriver.
  6. Shark Navigator Lightweight Upright Head Shell Replacement: 6 단계, 이미지 2개 중 1개 Shark Navigator Lightweight Upright Head Shell Replacement: 6 단계, 이미지 2개 중 2개
    • Remove the four 18mm screws located on the top corners and the bottom/middle of the vacuum head using a JIS 1 screwdriver.
  7. Shark Navigator Lightweight Upright Head Shell Replacement: 7 단계, 이미지 2개 중 1개 Shark Navigator Lightweight Upright Head Shell Replacement: 7 단계, 이미지 2개 중 2개
    • Remove the two 18mm screws located on the inside of the large wheels using a JIS 1 screwdriver.
  8. Shark Navigator Lightweight Upright Head Shell Replacement: 8 단계, 이미지 3개 중 1개 Shark Navigator Lightweight Upright Head Shell Replacement: 8 단계, 이미지 3개 중 2개 Shark Navigator Lightweight Upright Head Shell Replacement: 8 단계, 이미지 3개 중 3개
    • Remove the plastic cover by prying the plastic cover up using a plastic opening tool.
    • Prying in multiple locations may be necessary to create separation.
결론
작성자
3다른 기여자 명과 함께
Suzie
회원 가입일: 10/02/17
534 평판
안내서 4개를 작성함
Cal Poly, Team S4-G6, Livingston Fall 2017 Cal Poly, Team S4-G6, Livingston Fall 2017 회원
CPSU-LIVINGSTON-F17S4G6
3 회원들
안내서 12개를 작성함
1가이드 댓글
I have been doing exactly what the steps require but have not been able to remove the cover. Each time I am able to release one side the other side snaps back and the fixit tools fall out or fall inside.
Please give me any suggestions to accomplish removing the cover. Thank you.
Diane Snelling - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 8
전체 시간: 1,139
