주요 콘텐츠로 건너뛰기
Shark Navigator Lightweight Upright Motherboard Replacement
필요한 것
  1. Shark Navigator Lightweight Upright Motherboard Replacement, Head Shell: 1 단계, 이미지 2개 중 1개 Shark Navigator Lightweight Upright Motherboard Replacement, Head Shell: 1 단계, 이미지 2개 중 2개
    • Detach the hose connected on the bottom of the vacuum by pulling it out of the casing.
  2. Shark Navigator Lightweight Upright Motherboard Replacement: 2 단계, 이미지 2개 중 1개 Shark Navigator Lightweight Upright Motherboard Replacement: 2 단계, 이미지 2개 중 2개
    • Lay the vacuum on its side.
    • Press in the black, rubberish button located on the back of the vacuum to detach the vacuum head from the body.
  3. Shark Navigator Lightweight Upright Motherboard Replacement: 3 단계, 이미지 1개 중 1개
    • Flip over the vacuum head so the brush head is facing up.
  4. Shark Navigator Lightweight Upright Motherboard Replacement: 4 단계, 이미지 3개 중 1개 Shark Navigator Lightweight Upright Motherboard Replacement: 4 단계, 이미지 3개 중 2개 Shark Navigator Lightweight Upright Motherboard Replacement: 4 단계, 이미지 3개 중 3개
    • Remove the small front wheels with a metal spudger by inserting the metal spudger in front of the wheel and slowly prying up. This will free the wheel and reveal the screw beneath it.
    • Repeat this for the other wheel.
  5. Shark Navigator Lightweight Upright Motherboard Replacement: 5 단계, 이미지 2개 중 1개 Shark Navigator Lightweight Upright Motherboard Replacement: 5 단계, 이미지 2개 중 2개
    • Remove the two 18mm screws with a JIS 1 screwdriver.
  6. Shark Navigator Lightweight Upright Motherboard Replacement: 6 단계, 이미지 2개 중 1개 Shark Navigator Lightweight Upright Motherboard Replacement: 6 단계, 이미지 2개 중 2개
    • Remove the four 18mm screws located on the top corners and the bottom/middle of the vacuum head using a JIS 1 screwdriver.
  7. Shark Navigator Lightweight Upright Motherboard Replacement: 7 단계, 이미지 2개 중 1개 Shark Navigator Lightweight Upright Motherboard Replacement: 7 단계, 이미지 2개 중 2개
    • Remove the two 18mm screws located on the inside of the large wheels using a JIS 1 screwdriver.
  8. Shark Navigator Lightweight Upright Motherboard Replacement: 8 단계, 이미지 3개 중 1개 Shark Navigator Lightweight Upright Motherboard Replacement: 8 단계, 이미지 3개 중 2개 Shark Navigator Lightweight Upright Motherboard Replacement: 8 단계, 이미지 3개 중 3개
    • Remove the plastic cover by prying the plastic cover up using a plastic opening tool.
    • Prying in multiple locations may be necessary to create separation.
  9. Shark Navigator Lightweight Upright Motherboard Replacement, Motor: 9 단계, 이미지 1개 중 1개
    • Locate the motor on the top right corner of the vacuum head shell.
  10. Shark Navigator Lightweight Upright Motherboard Replacement: 10 단계, 이미지 3개 중 1개 Shark Navigator Lightweight Upright Motherboard Replacement: 10 단계, 이미지 3개 중 2개 Shark Navigator Lightweight Upright Motherboard Replacement: 10 단계, 이미지 3개 중 3개
    • Remove the belt from the motor gear by sliding the belt to the right.
  11. Shark Navigator Lightweight Upright Motherboard Replacement: 11 단계, 이미지 3개 중 1개 Shark Navigator Lightweight Upright Motherboard Replacement: 11 단계, 이미지 3개 중 2개 Shark Navigator Lightweight Upright Motherboard Replacement: 11 단계, 이미지 3개 중 3개
    • Remove the white metal wire connector from the motor.
    • The white cable is positive.
  12. Shark Navigator Lightweight Upright Motherboard Replacement: 12 단계, 이미지 2개 중 1개 Shark Navigator Lightweight Upright Motherboard Replacement: 12 단계, 이미지 2개 중 2개
    • Remove the black metal wire connector from the motor.
    • The black cable is negative.
  13. Shark Navigator Lightweight Upright Motherboard Replacement, Motherboard: 13 단계, 이미지 2개 중 1개 Shark Navigator Lightweight Upright Motherboard Replacement, Motherboard: 13 단계, 이미지 2개 중 2개
    • Remove the two 12mm screws using a JIS 1 screwdriver.
  14. Shark Navigator Lightweight Upright Motherboard Replacement: 14 단계, 이미지 1개 중 1개
    • Remove the wire housing by removing one 12mm screw using a JIS 1 screwdriver.
  15. Shark Navigator Lightweight Upright Motherboard Replacement: 15 단계, 이미지 2개 중 1개 Shark Navigator Lightweight Upright Motherboard Replacement: 15 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Lift up the wire housing from the plastic base using tweezers.
  16. Shark Navigator Lightweight Upright Motherboard Replacement: 16 단계, 이미지 2개 중 1개 Shark Navigator Lightweight Upright Motherboard Replacement: 16 단계, 이미지 2개 중 2개
    • Free the black and white cables that were previously attached to the motor from their slot.
  17. Shark Navigator Lightweight Upright Motherboard Replacement: 17 단계, 이미지 2개 중 1개 Shark Navigator Lightweight Upright Motherboard Replacement: 17 단계, 이미지 2개 중 2개
    • Free the motherboard and its connecting parts from the rest of the vacuum.
    • Turn the motherboard upside-down and spread wires out.
  18. Shark Navigator Lightweight Upright Motherboard Replacement: 18 단계, 이미지 2개 중 1개 Shark Navigator Lightweight Upright Motherboard Replacement: 18 단계, 이미지 2개 중 2개
    • Heat the wire connection's solder joint until the joint looks wet and liquidy.
    • While maintaining contact with the solder iron, free the wire end by pulling the wire away from the board with the tweezers.
    • For instructions on how to solder properly please refer to this soldering technique guide. 연결부 납땜 및 납제거 방법
    • Remember which cables were soldered onto where. You will have to re-solder the cables back onto the same joint.
    • Solder iron is extremely hot and should be handled with care. Always wear eye protection when soldering.
  19. Shark Navigator Lightweight Upright Motherboard Replacement: 19 단계, 이미지 3개 중 1개 Shark Navigator Lightweight Upright Motherboard Replacement: 19 단계, 이미지 3개 중 2개 Shark Navigator Lightweight Upright Motherboard Replacement: 19 단계, 이미지 3개 중 3개
    • Completely free the cable by pulling it out of the board.
    • Repeat for the remaining cables. There are 4 total.
결론
작성자
4다른 기여자 명과 함께
Suzie
회원 가입일: 10/02/17
534 평판
안내서 4개를 작성함
Cal Poly, Team S4-G6, Livingston Fall 2017 Cal Poly, Team S4-G6, Livingston Fall 2017 회원
CPSU-LIVINGSTON-F17S4G6
3 회원들
안내서 12개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 14
전체 시간: 1,760
