주요 콘텐츠로 건너뛰기
Shark Navigator Motherboard Replacement
필요한 것
  1. Shark Navigator Motherboard Replacement, Roller Brush Compartment: 1 단계, 이미지 1개 중 1개
    • Pop out the two small wheels located on the front end of the bottom of the roller brush compartment.
  2. Shark Navigator Motherboard Replacement: 2 단계, 이미지 2개 중 1개 Shark Navigator Motherboard Replacement: 2 단계, 이미지 2개 중 2개
    • Remove the 10 Phillips screws located on the bottom of the roller brush compartment. (Two of these screws are located under the wheels from the previous step.)
    • The screws have varying lengths, so keep track of where each one goes for reassembly.
  3. Shark Navigator Motherboard Replacement: 3 단계, 이미지 1개 중 1개
    • Remove the white plastic cover to expose the roller compartment underneath.
  4. Shark Navigator Motherboard Replacement, Motherboard: 4 단계, 이미지 1개 중 1개
    • There is one screw at the edge of the circuit board. Unscrew the circuit board before attempting to take it out.
  5. Shark Navigator Motherboard Replacement: 5 단계, 이미지 1개 중 1개
    • Take out the circuit board and replace with a new one. It may be better to allow a professional to re-wire the circuit board to the vacuum.
결론
다른 3명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Mara
회원 가입일: 03/27/15
493 평판
안내서 2개를 작성함
UMass Dartmouth, Team 5-4, Kish Spring 2015 UMass Dartmouth, Team 5-4, Kish Spring 2015 회원
UMASSD-KISH-S15S5G4
4 회원들
안내서 16개를 작성함
8가이드 댓글
Hi ..well done with the instructions.However I do have a Shark rotator vacuum NV501 .Unfortunately the motor on the brush is not working ,so I assume the motor is burnt.My request where could I find a replacement of the motor.I have searched a lot sites online but could not find a place to rebuild nor stock the same motor.Any help would be appreciated.Thank you.....To forward any information please do so on my email jacob.brown at hotmail.com thank you....
jacob - 답글
I couldn't figure out how to remove the bottom plate, your guide helped by informing me the last two screws are located under the little wheels. Thank you!
dylananon - 답글
When I had mine apart, two black rectangle magnet fell out, I can't figure out where the came from.
mardit - 답글
I had the same problem with the magnets - where do they go>
bjolivares1055 -
Also having problem locating both mother board and brush roller motor. Where can i purchase them?
Liz - 답글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 77
지난 30일: 153
전체 시간: 8,395
