주요 콘텐츠로 건너뛰기
Shark Navigator Motor Replacement
필요한 것
  1. Shark Navigator Motor Replacement, Roller Brush Compartment: 1 단계, 이미지 1개 중 1개
    • Pop out the two small wheels located on the front end of the bottom of the roller brush compartment.
  2. Shark Navigator Motor Replacement: 2 단계, 이미지 2개 중 1개 Shark Navigator Motor Replacement: 2 단계, 이미지 2개 중 2개
    • Remove the 10 Phillips screws located on the bottom of the roller brush compartment. (Two of these screws are located under the wheels from the previous step.)
    • The screws have varying lengths, so keep track of where each one goes for reassembly.
  3. Shark Navigator Motor Replacement: 3 단계, 이미지 1개 중 1개
    • Remove the white plastic cover to expose the roller compartment underneath.
  4. Shark Navigator Motor Replacement, Motor: 4 단계, 이미지 1개 중 1개
    • Once the vacuum top is opened, you can simply remove the motor as shown in the image.
    • Make sure to untangle or unhook any wires that are connected to the motor.
    • Once this is done, you can replace the old motor with a new one.
결론
작성자
3다른 기여자 명과 함께
Molina Oung
회원 가입일: 03/27/15
289 평판
안내서 1개를 작성함
UMass Dartmouth, Team 5-4, Kish Spring 2015 UMass Dartmouth, Team 5-4, Kish Spring 2015 회원
UMASSD-KISH-S15S5G4
4 회원들
안내서 16개를 작성함
6가이드 댓글
Hi Where could I get a replacement motor from for NV501 model shark rotator .Or have the same motor rebuilt...Any help would be appreciated thank you.....
jacob - 답글
The screws on the bottom of roller brush compartment ARE NOT phillips head!!!!!!!!!!!!!!!!!!!!
randy - 답글
The screws are Phillips on mine. It may be a case of availability. If the manufacturer found a better deal on a different style of screw, they may have changed it.
Joe Evans -
Mine has the security Torx screws. Those are the Torx bits with a round hole in the center. Anyway, what is the model number of the motor? I need a replacement motor, and am finding several in eBay but don't know which one is correct.
Roger -
Have no suction but the roller still spins can it still be the Motor ?
Thompson Mick - 답글
댓글 쓰기
조회 통계:
지난 24시간: 5
지난 7일: 20
지난 30일: 105
전체 시간: 17,624
