주요 콘텐츠로 건너뛰기
Shark Navigator Roller Brush Replacement
필요한 것
  1. Shark Navigator Roller Brush Replacement, Roller Brush Compartment: 1 단계, 이미지 1개 중 1개
    • Pop out the two small wheels located on the front end of the bottom of the roller brush compartment.
  2. Shark Navigator Roller Brush Replacement: 2 단계, 이미지 2개 중 1개 Shark Navigator Roller Brush Replacement: 2 단계, 이미지 2개 중 2개
    • Remove the 10 Phillips screws located on the bottom of the roller brush compartment. (Two of these screws are located under the wheels from the previous step.)
    • The screws have varying lengths, so keep track of where each one goes for reassembly.
  3. Shark Navigator Roller Brush Replacement: 3 단계, 이미지 1개 중 1개
    • Remove the white plastic cover to expose the roller compartment underneath.
  4. Shark Navigator Roller Brush Replacement, Roller Brush: 4 단계, 이미지 1개 중 1개
    • Lift the roller brush out of its holders.
결론
다른 42명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Jeremiah Shyne
회원 가입일: 03/27/15
1,403 평판
안내서 2개를 작성함
UMass Dartmouth, Team 5-4, Kish Spring 2015 UMass Dartmouth, Team 5-4, Kish Spring 2015 회원
UMASSD-KISH-S15S5G4
4 회원들
안내서 16개를 작성함
35가이드 댓글
Instructions where so easy to follow & right on the money. It took me 11 min from start to finish. PERFECT!!!
Cole bohn - 답글
Very helpful and easy. Thank you.
Kristi cox - 답글
Thank you. The owner's manual doesn't take into account needing to disassemble to clean the brush, for those of us with super long hair. Your instructions pointed out the screws under the wheels that we were missing.
birdofpyre - 답글
Ive uscrewed everything and this white piece seems to be stuck toward the rear. I even took the back whells off.
falynkinsey - 답글
Thank you so much. After having had to send in vac due to recall could not bare to part with it again to fix the belt. Your instructions for very clear and easy to follow. Thank you June
interhome1 - 답글
댓글 쓰기
조회 통계:
지난 24시간: 14
지난 7일: 161
지난 30일: 596
전체 시간: 103,943
